Put a cd in car cd player and it won't play or come out. Keeps saying "CD error"
SOURCE: 2002 F250 4X4 Supercab CD player stuck
Cd mechanism issue, may be a broken gear.
It would not be able to read discs or load them, or throw them out.
SOURCE: cd changer stuck
I had to take the changer out of the console and get the CD that was hung up. I then replaced everything.
SOURCE: 6 disk cd player error
This is a part failure in the mechanism that loads and ejects the disk, there are no repair manuals avail to either the tech or the consumer, the only place that the factory gives this info and parts to are factory authorized repair stations, bottom line you must pull the deck and contact a Ford dealer in your area for location of the nearest factory repair station. I was dealer tech for 20 years and that is how it is done.
SOURCE: CD player will not release CD's
Anti-theft on radio. Should be a code on a card in owners manual.
SOURCE: I have a 2001 ford
You need to remove the stuck CD...place another (old) CD under the stuck CD...keep tgrying to insert...will eventually kick out the stuck CD...be sure to clean with Disc cleaner to reduce chance of happening again...:)
