Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
Ice maker makes very little Ice and the cubes are small.
I have replaced the water filter cartridge thinking it could be restricting
the flow. No change. Any suggestions would be appreciated.
Thank you.
  • filmman Oct 03, 2009
    Plastic gear in the timer motor was cracked.
    It was replaced and everything works fine.
  • 739 Answers
The amount of ice is not dependent upon water flow, well as long as you do have flow, when enough water is in the maker it will shut off the supply.....ice quantity is dependent upon the length of the freezing cycle, the shorter the cycle the more harvests per hour. Adjust the timer so that you get complete freezing, but just barely
Posted on Jun 04, 2009
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Ice maker is not making ice.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Ice maker is not producing ice and the control light is blinking red
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Install nocold refrigerator icemaker
Jun 02, 2015 | Refrigerators
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker inside kitchen aid fridge not making full cubes
Items to check would be ,
1 Is the filter restricted with sediment in the water?
indicator would be water flow decreased thru door dispenser.
2 Is the tap a line (if used) restricted with mineral deposites where the sleeve pierces the water pipe.
3 is the valve itself restricted with sediment due to not using a filter?
4 a kinked water line (copper) or pinched plastic line could also cause this problem.
eliminate each and you should find the problem.
Jun 17, 2014 | KitchenAid Superba Architect KSCS25INSS...
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
My icemaker for the LG French Door/Bottom Freezer Model # 25770SW is making very little ice.
If the ice maker is producing ice poorly, making small cubes or too few cubes then it means your ice maker is probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that is not cycling properly.
First, check the water line that's attached to the back of the refrigerator. Make sure it is having a good water flow. If the flow is poor, that means you will have to, repair, clean, or replace the tubing or the shut-off valve that supplies the water in the ice maker.
Second, check the water-inlet valve. You will need to replace the water inlet valve if it has failed.
Third, check the freezer temperature. It should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Lastly, check the ice maker mold thermostat. Make sure that it's cycling properly.
The above is what you need to check on........
I hope this helps....
Take care.
Mar 08, 2011 | Refrigerators
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker makes small cubes
Check or change the water filter, leading into the machine.
If that is not the problem ,disconnect the water lone from the machine and see if their is sufficient flow comming through the line.
Oct 19, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
148 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
