The wooden handle is loose. This knife has never been used but has been in the box for 5 years. Can the handle be repaired inexpensively?
Need to know if there is a reason to try to repair knive. It was represented to be an expensive knife. It looks to be a "Birds Eye" maple handle. Help is appreciated.
These older models are hard to find when you need them. The only place I've found them was on Ebay, and I see there is one currently for sale (new in box). Here is a link if you decide to go that route.
Hi! It sounds like one of your blades is jammed on something. Easy to fix! Make sure the garbage disposer is switched off (not necessary to unplug). Any large wooden handle tool (not a wooden spoon or plastic broom-they snap..1 to 1 1/2 inch diameter) axe handle, wooden broom ect., put the handle into the bottom garbage disposer on an angle. get nthe handle against the bottom and side where they come together. With gentle pressure, rotate the wooden handle until you feel it stop. This will be a blade..there are usually 2 at opposite sides inside there. Push against it till you feel it break loose in a clockwise direction. Once forced loose it should run again. Whatever jammed it will still be in there so you can to grind it up but it's advised to look with a flashlight and locate and remove the object. FYI...if your disposer is ever non-responsive, there is a red button either on the bottom or back of the disposer. This is a re-set button. Good to know. Let me know if you still have problems. Hope this fixes it for you!
I had to replace all the wood on my grill. I used a wooden clothes dowel rod for the lid handle (planed one side flat, routed a grove for the insert and kept the old wooden insert), replaced the shelves with 5 in. redwood fencing slats (2 per side works better than the original 3 in. slats), and used a smaller dowel for the bin handle. It is now better than new.
YOU HAVE A FAULTY HEATER RESISTOR..LOCATED IN PASS SIDE OF HEATER BOX..YOU MUST REMOVE A COVER FROM BOTTOM OF DASH..THERE WILL BE 5 WIRE CONNECTOR AND 2 SCREWS HOLDING IT INTO HEATER BOX..GET A NEW ONE FROM YOUR LOCAL DEALER..FAIRLY INEXPENSIVE AS WELL..YOU MAY NEED TO ENLARGE OPENING IN HEATER BOX IF YOUR RESISTOR IS ORIGINAL..YOU CAN USE AN UTILITY KNIFE TO DO THIS..FAIRLY COMMON PROBLEM ON THESE VEHICLES
