Question about Uniden Cordless Phone
Battery charge length of time
Can I leave my phone off its base and take it to the bedroom over night?
    Sergeant:
  • 367 Answers
Yes.
Posted on Jan 16, 2009
Why do both incoming and outgoing calls cut off after a few minutes on base hand set?
It could just be a bad battery, swap battery's and see if the trouble follows. If so it is bad. Also on these lithium battery's you build the life to them, when it is fully charged, do not just use it for a few min. and put back on the base, if you do that's all they will last is a few min. after charged. Use it and leave off base, then get in the habit of only charging it at night and leave off base during the day. The battery should last 6-8 hours or more if not in use a lot.
Jul 22, 2015 | Lands Phones
Handset message "Warning check battery" after replacing new battery
Hello - did you put the phone on the charger with new battery and leave it there for 8-12 hours? If so then you may either have the wrong battery or your phone won't accept generic batteries (if it is generic). You can locate your phone model by looking under the base or finding it on this this site. Sometime it is normal to get an error message if you haven't let the battery fully charge. It may say it is charged but still important to leave on charger over night. Good luck:)
Aug 11, 2013 | AT&T Att Sl82118 Dect 6 0 Digital Cordless...
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
Does the monitor that stays in the bedroom need to be plugged in to the power supply at all times cause as per instructions and unplugged it loses charge. this is on the safety 1st digital monitors
Does the monitor that stays in the bedroom have a battery? Many monitors do not have a battery in the base.
Check for a battery: If there is one, it probably needs to be charged for at least 12 hours. If there is no battery, it needs to be plugged in to function.
Oct 15, 2010 | Safety 1st Baby Monitor
Lg ks360 battery problem,, charge it up fully and battery dies in 2 hours my phone is dead in the morning when i left it the night before with only one bar of the battery down. What can i do to solve this...
Im not sure if this goes for phones...
But I noticed that when you get something with a charger and you seem to over-charge it (Leaving it constantly plugged in or charging it for long periods of time after its fully charged) it actually makes the life of the object shorter....
It could be that because you've been leaving it over night to charge its been eating at the LGs battery...
But like I said, im not sure...
Obviously you can't fix something like that...
Jun 02, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Battery
the batteries often go bad especially if you leave it on the charger all the time. i was told to leave it off charge all day and put it on at night and they would last longer. any ways take one of the batteries out of one of the other phones if they are the same and put in the one that will not hold a charge if it works fine go and buy a new battery. you can usually get them a wal mart very reasonable.
Dec 20, 2008 | Uniden Cordless Phone
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
Thomson GE DECT 6.0 28213 Cordless Telephone
I finally find a way to stop this problem from occuring : never leave your phone on the charger with the battery isnt empty !
I know this sucks because what best place to put your phone at night than its base. But try it and it will work (unless your battery is already damaged). In the morning when i go to work, I charge it for 8 hours, then when I come back, I take it off the charge until next morning.
I used to put it on the charge for all night and all day until I read an interesintg post :
http://en.allexperts.com/q/Telephony-Clecs-Long-2450/Cordless-phone-interference.htm
Since I have been doing this, I didnt get any more problems with my phone.
May 28, 2008 | Thomson GE-28115FE1 Cordless Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Uniden Cordless Phone Logo
24 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
