Question about Microsoft Excel for PC
Excel Formula How to find the highest value in a range of cells (I15:I37) and whichever cell is the highest give it a set value (H11) on its row but in different coloum
  • Anonymous Jan 18, 2009
    yes
  • 4 Answers
Highlight the range of cells that contain the numbers you want included. Click on the cell where you want the highest value displayed. Click on the paste function button select MAX and click <OK>
Posted on Jan 16, 2009
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
Feb 17, 2009 | Microsoft Excel for PC
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Excel Formula
Place the following in the cell you want to display the result:
=MAX(l15:l37)
Logically this reads the cells you have circled, reads the highest #, and places it in the cell you put the formula in. ( you have indicated cell m16 in the screencap)
Hope this is what you are looking for.
Jan 16, 2009 | Microsoft Office Professional 2007 Full...
Count how many times a value appears in a column, based on anothe
Go to the cell you want this total in.
Type this formula:
=SUM(IF(Sheet2!C1:C10="EME",IF(Sheet2!N1:N10=1,1,0)))
make sure you end the formula with CTRL - SHIFT - ENTER which makes it an array formula. If you forget, go back to the cell with this formula and press F2 (to edit the cell) and press CTRL - SHIFT - ENTER to convert it to an array formula (Excel will show a little {...} around the formula).
Dec 21, 2008 | Microsoft Excel for PC
HLOOKUP IN MS EXCEL
lookup value = value searched
table array = database
topmost row of lookup array must contain the data IDs and all IDs must be sorted in ascending order.
row index number = row number containing data to be shown; first row = 1
hlookup(x,tablearray,y) will look for x on the first row of the lookup table and return the value in the cell on the yth row
if formula cannot file exact x, it will look for the value closest to. but not greater than x
Nov 13, 2008 | Computers & Internet
H look up
Hi vrusha,
Your right hlookup is very simular to vlookup, the key difference is it searches along the top row of the table, finds the matching data and gives you one of the below cells (depending on how you write the formula), just think of a vlookup on it's side.
The formula works like this:
=HLOOKUP(lookup value, table, row_index_number, range_lookup)
lookup value = is the value you want to match against the table i.e. ABBA
table = the range of cells that make up the table you want to search i.e. A1:D300
row_index_number = the number of rows from the top of the table you want to get the value from, 1 is the top of the table, 2 is directly below
range_lookup = if you want an exact match type FALSE, if you want the nearest match type TRUE
Jul 17, 2008 | Microsoft Office Professional 2007 Full...
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
May 16, 2008 | Microsoft Excel for PC
Excel formula
Assuming that all of your data is in a single row number 4 and between columns N and PF
Try:
{=OFFSET(N4,0,MATCH(TODAY(),N4:PF4,0)+1,1,1)}
The MATCH function looks up the value of today() in the range N4 to PF4 and returns the number of columns offset from the beginning of the range. (The 0 here does an exact match)
The OFFSET function returns a value from a cell a specified number of columns from a reference cell, in this case N4, which is the first column that contains the search data. We need to add on to this value to skip the Interest column.
Regards,
Daryl
Jan 25, 2008 | Computers & Internet
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
