Question about Honeywell Programmable Thermostat Heater
Dellllllllllluxe programmable thermostat chronotherm plus iv
I cannot get power to thermostat. i have checked the breakers and the furnace doors. is there any other thing to check. i'm sooo cold. patti
    Scholar:
    New Friend:
  • 70 Answers
Does your thermostat have batteries. What is the brand of furnace and model # . Does the furnace have a pilot light or is it electronic ignition. if you need heat you can take thermostat of wall and take wires that are labeled r and w and wire nut them together to see if furnace comes on. Make sure you turn breaker off to furnace first before you take thermostat off the wall. If furnace comes on after you turn power back on after you connect those two wires together then you will probally need new thermostat. If not you have a problem with your furnace. If you have any questions after you try this feel free to ask any more questions.
Posted on Jan 16, 2009
AC chronotherm IV plus thermostat has no display and AC has gone off and will not come back on.
Either the 5 amp fuse is blown on the indoor unit, transformer is bad or float switch is tripped.
May 28, 2017 | Amana Heating & Cooling
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
I have a braeburn 3200 thermostat that has went blank on me yesterday. I have checked the fuse box, no tripped breaker, i have checked the switch on the furnace, its on, and there are no batteries. Im not...
If there are no batteries in the thermostat then the furnace was being used to power it. To make sure it is just a thermostat problem, you can jumper the power and heat wires that connect to the thermostat, usually red and white, or terminals R and W. If the furnace comes on, then you need a new thermostat. If that doesn't work, you have lost power at the furnace somehow. If the breakers are good, and the furnace switch is on, then you can have a bad door switch inside the furnace, a bad transformer in the furnace, or a bad circuit board if equipped. If there is a circuit board, they usually have fuses somewhere on them too that can blow. Just be sure to cut power off at the breakers before checking. Hope this helps and good luck!
Dec 11, 2010 | Honeywell Electronic Programmable...
My home too is stuck at 78 degrees with the Chronotherm IV
a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm IV Plus requires frequent resetting.
Check to see if you have wires going to a C/C1 terminal. The older chronotherms used a transformer to supply 24 volts to power the clock. If in fact you do have these terminals, then I would suggest checking the output voltage on the transformer, (secondary (24v)side) to ensure it isn't close to dead. Hope this helps
Nov 28, 2008 | Honeywell Programmable Thermostat Heater
Honeywell chronotherm IV plus controller
Sorry to hear that, not to be the perveyor of the obvious but for everyone else.. ALLWAYS check and make sure your pins are straight when you do a battery change. OMG they charged you 300 for a thermostat? im very sorry
May 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
187 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
