Question about Car Audio & Video
Outside temp guage is wrong
The display that shows the outside air temp is showing -35. can i reset it?
  • 120 Answers
Clean the connections from the sensor, one of the is probably corroded just enough to add resistance.
Posted on Jan 17, 2009
Outside temp suddenly shows -40randomly when it is 80+F out.A/C stops working when guage shows erroneous temp. Replaced ambient sensor, cleaned wires near battery.any other thoughts?
Check or just replace the coolant temp sensor. This sensor will also tell the computer -40 and stop the a/c if bad connection or faulty part.
Jul 15, 2015 | Saturn L-Series Cars & Trucks
Ambient outside air temp sensor
i may be wrong but that sensor is for the ac not for engine operation and at 113 if its not that hot then the sensor is bad but if its summer its ok,, your engine works with intake air temp
Nov 25, 2013 | 1996 Jeep Cherokee
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
2004 Ford Freestar: Outside temp guage reads -41 all the time. How do I reset or test etc.
The temp sensor behind the grille is bad when they go bad they show -41, replace the sensor and retest
Apr 07, 2010 | 2004 Ford Freestar
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Ambient temp guage problems
The temperature sensor is located in front of the radiator on the passenger side. Replacements cost approx $25.00.
Jul 23, 2008 | 2000 Chevrolet Impala
Temperature guage
Right behind the grill around the rad. support on the passenger side (usually) there is a sensor called an ambient temperature sensor. That gives your outside temp. on your rearview mirror.
May 15, 2008 | 2003 Chevrolet Suburban 1500
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
