Ups trouble shooting
May you help us to resolve this problem .we have four ups in our power room ,2ups of 20 kva and 2ups of 60kva.both of them are coupled .What is the really problem of this,one of ups 60kva is faillure down every time when the main power cut off
  • 47 Answers
Yes ehsan is right, you need to replace battery. But before buying you should check the main power section of the UPS.
Posted on Jan 27, 2009
  • 112 Answers
You need to replace the battery.
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
I have a power ware UPS 20 kva series 9355-20-n-0 it has got an error of heatsink temperature sensor failed which part is fixed so that i can remove it and fix it.
Hi guys, I just replaced 40ah x36 batteries, 12v into 40kva ups. With my cal, it suppose to back for about 40min at 60% loading. But now my client said they only have 10min back up. What may be wrong? Please help out
Jul 22, 2017 | Power Computers & Internet
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
What problem a change over switch caurses to a 60kva diesel gen set
is the auto transfer switch rated to handle a 60 kva gen set cus you can use a larger auto switch on a smaller gen set but it don't work the other way cus you'll be burning up wires and contactors and have a fire !
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
APC SUVT 20 kVA power-up on batteries but not on mains
Dear If UPS working on MAINs but just not wakeup on MAINs then only 3 capasitors need to change.. for further you can diractelly contact @ techdata41@gmail.com
Nov 21, 2012 | APC Computers & Internet
AC unit botton (High, Low. Med, Auto) is acting as the power button, cutting unit off and on instead of changing cycles.
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Jul 28, 2011 | GE Electronic Room Air Conditioner AGW12AH
Please tell me how many computers a 20 kva ups( liebert )can support.
It really depends on how large your computers are and what they actually require. A 750 W Cisco Server will require usually a 1.5Kva UPS and give you around 7-9 minutes depending on the model of UPS.
Oct 08, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Can u esplain about trouble shooting in diesel generator
my 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
Oct 25, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Toshiba 65h82 picture trouble
Its most likly the Hi voltage/focus block assy. Or there are bad capacitors in the sweep power supply. You should call toshiba and get the number of an authorized Toshiba repair shop.
Oct 08, 2006 | Toshiba 65H82 65" Rear Projection...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
