Question about Kenmore 73822 / 73824 Bottom Freezer Refrigerator
My refrigerator has started making a great deal of noise.
The refrigerator is ten years old, and I am wondering if this could be a problem with the condenser. In addition the bottom mount freezer has a drip causing an ice build up on the floor of the unit.
  • anmac Jan 16, 2009
    This refrigerator is a Kenmore, Bottom-mount no-frost, Model 18.
    It does not have a label inside the door, I am getting this info from the owner's manual.
    I am wondering if the excessive noise (similar to an airplane flying by) could be caused by a problem with the condenser (it is the only part of the appliance still under warranty).
    There is no ice-maker the water is dripping into the freezer from small hole inside, which I assume is meant for air flow, as it appears to be a normal part of the appliance.
  • Mark Egan May 11, 2010
    I don't understand one of your problems. What problem are you having that makes you think there is a problem with the condenser?
    As for the drip and ice buildup in the freezer, I assume this unit has an ice maker.
    First, check that the floor is level that the appliance sits on.
    Second, if you have an ice maker, are the ice cubes made today the same size as the ice cubes the maker originally made? If they are smaller, there is probably a crack in the ice mold, depending on the model and design of the ice maker. I will need to know the exact model number of the appliance, which is usually found on a label somewhere inside the door frame when you open the door of the appliance.
    President:
  • 1,214 Answers
The only part of the system that is still under warranty is the sealed system. The condenser fan, which is about the only thing that can sound like an airplane in the back of the unit, is only warranted for a year.
What often happens is there is a shroud around the fan that is made of cardboard. The cardboard warps over time, or has gotten wet or damaged in such a way that it comes into contact with the fan as it turns. You can usually get under there with a screwdriver or nut driver and loosen screws, then readjust the shroud so the fan will not hit it, then tighten the screws back down.
Now, sometimes the noise is coming from the compressor, but that whirring noise is usually hard to hear over the condenser fan noise. If it is the compressor, don't worry about it. It's not covered under warranty anyway, and that's just the way they sound sometimes. And the compressor is not serviceable anyway. But I doubt that is the problem.
Posted on Jan 16, 2009
  • Mark Egan Jan 16, 2009
    And I forgot to add, the small hole dripping inside -
    Any "small" holes inside are not big enough to allow sufficient air to flow through for any reason. Are the holes intended for installation of the ice maker? If so, there should be a plug in them. What your getting is condensation that builds up around the outside of the shell of the refrigerator, draining down and finding the hole. Chances are, the water is supposed to go a different route, but without the ice maker, it finds the hole first.
    If that is the case, measure the hole diameter, and go to a home center and buy a plastic plug (hardware section) that will fill the hole. Make sure if that there is not a matching hole on the outside of the cabinet as well. If so, measure it, and buy a plug for it too. It would also be good to use an RTV sealant on the hole on the outside.
Refrigerator intermittent humming sound
If it's not causing any problems to the overall operation of the unit itself, I wouldn't worry about it.
May 14, 2012 | Sub-Zero Refrigerators
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
My refrigerator is over 5 years old. the refrigerator is making a rumbling noise and a beeping noise. i have switched it off hoping that it would reset itself.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | LG Refrigerators
9 year old Kenmore refrigerator is making a lound noise
if you are handy you get the model# of the refrigerator if is the fan in freezer you can change it you have to know were the noise comming from
Apr 07, 2009 | Kenmore Refrigerators
Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Mar 20, 2009 | Refrigerators
Kenmore 4.6-cu/ft refrigerator makes unusual vibrational noise
probably is the compressor become noisy but it doesn't mean that it will fail
Oct 08, 2008 | Refrigerators
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
Nov 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 73822 / 73824 Bottom Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
