Question about Alesis iO | 2 Sound Card
Io/2 will not install on my i mac
The owners manual says using osx its just a case of plug in and go. I connected the io/2 a pop up appeared would you like to install this device? I clicked on yes, nothing else happend. I guess I have spent around 30 hours trying to make sense of this. The owners manual is wofully insufficient. I need help badly!
The io/2 usually asks you to install and when you click yes it should be instantly installed so you can use it
Posted on Jan 12, 2010
Driver compaq evon610c de video
Posted on Jan 16, 2009
Need to update my ipad 2 to iOS 7.1
There are two ways to upgrade the iOS of your iPad
- via connecting the device to iTunes on a computer
- or directly from within the device
so in your case you can try connecting the iPad to a computer with iTunes installed
  • Connect your iOS device to your computer using an USB cable. Wait for iTunes to open and connect to your device.
  • Click on device button to the left of the iTunes Store button in the top right corner in iTunes.
  • Hold down on the option key (Mac) or the shift key (Windows) and click the "Check for Update" button in the Summary pane. Browse to the .ipsw file you downloaded and select it.
  • Do not disconnect your device until the update has finished.
  • If necessary, restore your device from the previous backup and sync with iTunes.
need-update-ipad-2-ios-7-1-qrl052hdp2kg0kvuqxssgusw-4-0.jpg need-update-ipad-2-ios-7-1-qrl052hdp2kg0kvuqxssgusw-4-2.jpg Install iOS 7 0 4 update on iPhone or iPad Tutorial
Apr 06, 2014 | Apple iPad 2 Wifi 16GB
I have a Mac osx g9 and IO don't know how to install bluetooth do I have to buy something or download it?
Go to
Finder » Applications » System Preferences
Under the Internet & Wireless section there is a Bluetooth option. Click on this.
Make sure both 'On' and 'Discoverable' are clicked.
Dec 25, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
USB to serial converter will not link to Macbook
the mac is still a mac but running windows, is sewing machine pc/mac compatible? if it is then boot under osx if u cant its not osx compatible only pc
Apr 24, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Lexmark 2600 scanning to MAC-no can do
Edward, I have this same problem. Were you able to solve it? Anyone, can you help? I have installed the drivers. When I connect the printer to my Mac, it launches ImageCapture and previews the scan fine. But I am unable to get the "scan" button to become active, adn there is no place to save the scan. If I click "save pdf to iphoto" it saves a pdf of the entire screen, rather than just the photo. Appears not to be Mac compatible for scanning purposes. Thank you for your help.
Jul 12, 2009 | Lexmark X2600 InkJet Printer
I am trying to install software onto my MAC OSX and it will not work. Says cannot operate in DOS mode. I do not know what to do. The UM175 says Mac OSX compatible. Help!
I know sounds dumb but it appears your putting the wrong disc in the drive. Kind of the same error if you try to install a windows file.
Plug and play and update.
Mar 22, 2009 | Computers & Internet
Blinking folder with ? mark blue screen
yes youve just had a corrupted osx. use the osx disks supplied to you with the laptop to re-install
1. take the cd out of the paper case
2. inser the cd into the laptop
3. press power and hold "C"
4. wait..wait..wait
5. it will start setup and follow instructions.
if it doesn't install, you need a new hard drive.
Mar 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
Alesis iO | 2 Sound Card Logo
419 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
