Question about Samsung HL-P5063W 50" Rear Projection HDTV
TV shuts itself off
My 4 yr old Samsung HLP5063 usually shuts itself off after about 30 minutes and the lamp light flashes. Once the light stops flashing the tv can be turned back on but will turn back off after only a few minutes. What needs replacement?
  • Bhoffman701 Mar 15, 2009
    My Samsung HLP 5063w turns itself off. It will go back on but turns itself back off a few minutes later. This usually stops after the third turn off. Any idea what is wrong?
    Scholar:
  • 73 Answers
Something is overheating or you've got leaking capacitors somewhere. I'd start with the ballast board. Its directly underneath the lamp housing. You can access and remove it through the lamp door. Replace that and if that doesn't solve the problem, comment again, and we'll move on to more complicated repairs. You haven't noticed any weird noises, humming, screeching or similar oddities from the set? Turn the set on with the lamp door open and bypass the switch with a piece of tape, if you hear something like a hum, you may have a bad color wheel motor.
Posted on Mar 23, 2009
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a 6 yr old Mitsubishi DLP WD-52327 does not fire up... When power is turned on tv makes a noise like a small air compressor for a few seconds and then stops after about 1 minute it does it...
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
Oct 23, 2010 | Televison & Video
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Jul 31, 2010 | Samsung HL-S5086W 50" HDTV
    Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
    Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
    Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
    TV TURNS OFF AFTER 20-30 MIN
    May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
    Samsung HL-P5063W 50" Rear Projection HDTV Logo
    320 people viewed this question
    Henry  Thomas
    Henry Thomas
