Question about Epson Stylus Color 740 InkJet Printer
The paper feed light just blinks. It won't accept any print jobs. There doesn't seem to be any paper jammed.
  • Epson Master
  • 705 Answers
If the Paper Out LED is flashing the machine believes there is paper in the machine. If you know there has not recently been a jam and paper was torn when it was removed then there may be a fault with the paper sensor. The most likely scenario is that there is something holding the paper sensor in the active position. This may be a torn piece of paper, or a foreign object that has fallen in. Easiest way to find out is remove the covers and the Auto Sheet Feeder (ASF) to check for objects and/or damaged sensor. The dismantling is straight forward and easy enough for anyone to do. If you are unsure about how to remove the covers and ASF get a service manual from http://www.TheServiceManualShop.com (if yours isi not listed, just ask them for it - they will have it) and use it to guide you through removing the parts. Once inside, look for the sensor paddle (flag) hanging down into the paper path on the home end (right side as you look from the front) If the flag is not hanging down it may just need a gentle pull or it may have got broken off. Again use the manual to help you reseat the flag. If it is broken you can rebuid the old one with a peice of modlers plastic (or even a drinking straw) and some glue. Obviously if you note any foreign objects in the mech, remove them. Reassemble and test it out.
Posted on Jun 19, 2007
  • Inky Fingers
    Inky Fingers Jun 19, 2007
    PE (Paper Exists) Sensor Assy
SOURCE:
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Warning lights blink upon startup, printer freezes
If the lights flash alternately then it is probably your waste ink pads that need cleaning
If the lights flash continuously check your printer for any outstanding documents in the print queue and cancel them then try again
Mar 30, 2010 | Epson Stylus Color 740 InkJet Printer
Epson Stylus Color 740.All indicators flashing (unknown printer error) Have tried troubleshooting advice. ie Turn of printer etc. But this does not correct problem. Any suggestions ?
Sounds like the printer may be jammed. When it goes through it's initialization process, it checks ink cartridge movement, and scanner arm, and when they don't respond correctly, the lights flash to indicate the fault(s).
Try to check for any paper jam first, and work the paper feed rollers slightly to see if they're bound up. Aside from this, it will have to be opened up most likely to see what's going on. I've seen mostly broken gears in the worst cases, but I've also seen paper jams, you just never know till you get in there. If it's under warranty, have it checked out, otherwise what have you got to lose by opening it up and investigating a bit- you might get lucky. If you choose to get it serviced, get an estimate first, since sometimes it's just better to buy a new one on sale, and the free cartridges that come with it are sometimes worth the price of the printer, so it's, basically, free. Good luck, wish I had a simple answer for you.
Mar 27, 2010 | Epson Stylus Color 740 InkJet Printer
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Failure to print
inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero tengo problemas para escribir no se como me enviaran lq forma de la lectura la pueda ver en español saludos desde chile
Feb 26, 2008 | Epson Stylus Color 740 InkJet Printer
Epson Stylus Color 740 InkJet Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
