Question about Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it still won't turn off.
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Posted on Feb 07, 2009
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson Stylus C46
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
Oct 07, 2008 | Epson Stylus C46 InkJet Printer
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Jun 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Cartridge Replacement
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
May 09, 2008 | Epson Stylus C44UX InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
224 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
