I tried to take pictures though the screen is blank, then I connected it to my computer to check if it was saved. Then, yes! the picture was saved to the memory. Then I disconnect the camera to the computer, but still, it only shows black screen. I think this not something about the LCD thing. Cause when I connect the camera to the computer, there is a message appear " USB - memory card and internal memory". If this is regarding the LCD, then that message should not appear either. Right? How can I fix this? Any help??? Thanks!
You're right in saying that if you get ANY onscreen message with the computer connected, the LCD and its driver circuits are likely OK. I don't have that exact cybershot, but I have had a few, and most have a menu item to turn off various screen content, including the entire display. Its likely a battery saving feature, but if you turn it on and hit the MENU button and still see nothing, there must be some actual defect. If all else fails, before contacting SONY, take the battery out and wait at least 5 minutes and then replace.
SOURCE: Pictures only save to internal memory, not memory stick...
DSC-W80 sybershot camera has facility when you insert Memory Stick in its slot, it automaticaly selects this memory card and starts saving data on it and internal memory got suspended.
Pls check memory stick 2GB and inert it correctly in memory slot in camera.
SOURCE: my sony cybershot dsc-t33 will not take any pictures
remove battery and or reset by inserting paperclip in reset hole near battery. try formatting the stick if this doesnt work. you will lose all saved picts so back up picts. to cpu
SOURCE: Sony DSC-T1 screen is black. Does not recognize
There may be the issue with the CCD (Image Sensor Device) of the Camera. This is a known issue with this Camera.
Refer this article to confirm this:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click
on the "Yes" button at the end of the page to create an online Repair
Request for sending the Camera to the Sony Factory Service Center.
SOURCE: I have a Sony cyber shot DSC-W80 I have some
In the menu, there should be an entry for "copy" or "transfer" or something to that effect that will permit the transfer.
SOURCE: Whenever I plug the USB cable into my camera, the
As far as I know, most cameras are made so that once it senses a USB cable (whether as being inserted physically or as a source of current), it reduces the camera to pretty much no more than a memory card reader. It is my belief this is so you can't use your camera directly with your computer, either as a web cam or using your computer as an immediate storage device.
