Question about Intel D946GZIS Motherboard
Video Problems. Well i decided to put together another pc. The Motherboard is the D946GZIS, The Video card is a GeForce 7950GT, the cpu is an Intel PD 940 3.20GHZ, and the cpu fan i bought is a Zalman CNPS7700(which i later found was not compatible with the motherboard). http://www.zalman.co.kr/product/cooler/7700-775MBlist_eng.htm I put the system together all was fine until I got to the cpu fan, which wouldn't mount right because the screws were not long enough to reach the mount. So i just made it work with some different screws, and it seemed to seat fine, it was a little tight but i didn't think it to be a big problem. So I managed to get it to boot and installed Windows vista. I installed the vista video drivers and thats where i had problems start, the system crashed halfway through the install and i couldn't get it to boot with video from the card (black screen). so I decided to plug it into the on board video on the motherboard and D-Sub on the monitor, It worked, i mean i got video at least but everything was all wobbly (text images). I was worried at this point , so i decided to troubleshoot the card. I took the Video card out and tested it in my other machine it was pretty warm but worked fine, no problems. So then i went to test my other Vid card in the messed up machine and it was just to damn big to fit in there. So I'm not sure if it is the PCI-E slot or the drivers or what but i sure don't like the looks of that wobbly screen. The temps in the pc stay between 29-34 degrees Celsius (about 85 Fahrenheit). I don't know what to do! should i send the motherboard back or is it something else ?
  • Hans Range
    Hans Range Jun 19, 2007
    wouldn't I get some kind of display during boot though? before the OS is loaded ?
  • 23 Answers
Well, I suppose it could be the motherboard, though I doubt it. I wonder did you check; the board, processor and graphics card on against the vista HCL (Hardware Compatability List) you should be able to find it on microsofts website. Unfortunately being a 64 bit OS, and considering how new it is, very few devices, software and drivers are actually designed to work on vista yet. I hear alot of complaints about vista not working properly. thruth is vista isn't the problem, other companies didn't keep up. anyway, I hope you can fix it. and honestly I hope it isn't a hardware compatibility issue. Either way Good Luck
Posted on Jun 19, 2007
SOURCE:
Will not reconize my geforce mx 440 video card,
I suppose you have already tried moving the geforce to a different slot. It this a card that requires being put in a particular type of expansion slot for video cards only? If so, do you have the geforce in that slot?
If not, put it there and try it again.
Does your PC also require the BIOS be "told" that you are trying to interface this specific video card? If so, then go into the BIOS by hitting the requisite key combination during boot, and then setting your BIOS to the proper settings for this card.
-a.
Dec 18, 2009 | Biostar P4M80-M4 Motherboard
GRAPHICS CARD PROBLEM
if this is your secound card tried you have a bad motherboard. If this is the first card try another card if that does not work Rules out mothboard at this time. All else fails try in another pc if works replace motherboard- thnaks if you like my solution please rate/review thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
No video output from Nvidia Geforce 9600GT 512MB
run the onboard if you have one and go into the bios there's normally an option to choose what order to boot graphics devices eg. PCIE>IGP etc hope this helps.
Apr 16, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Just upgraded VGA card to GeForce 9800GT. Now LG
Sounds like your Video card is not installed properly, you should take it out and then put it back securely into the motherboard. If its installed properly the monitor should come on during the start up screen at least to show the type of video card installed.
Also let me ask what model was your old Video card?
Mar 20, 2009 | LG L1915S 19" LCD Monitor
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
My colours is like a rainbow!!
I think the monitor needs a degauss.
mostly it will do the job
it happens because of magnetic reaction on monitors..
or the color sensor is gone....
Mar 09, 2008 | Pine Technology XFX GeForce 7950GT, (512...
XFX GeForce 7950gt 512mb AGP card overheated
lemmy29:
Here is the warranty info on your x7950gt card.
It has a lifetime warranty, if you registered it within 30 days of purchase.Please read the paragraph at the bottom for the full explanation.
http://www.xfxforce.com/web/support/showWarranty.jspa?regionId=1&productGenerationId=11979
Please let me know how you make out.
thanks
Oct 27, 2007 | Pine Technology XFX GeForce 7950GT, (512...
Xfx 7950gt agp 512mb
Hi, if you have got the drivers for this v/card then load them while you have your present one in place, if you dont have the drivers then go to the manufacturers website and get them . when you have loaded the drivers then check if you need to enable any changes in your bios. Change the card and if it is functional then you should have solved your problem. A card that advanced needs drivers far greater than you would find in XP. Regards mistyman
Aug 20, 2007 | Pine Technology XFX GEFORCE 7950 GT 512MB...
Will not display anything when booting up.
does your motherboard has a builtin video card? u probably connected your monitor to it which supposed to be connected to your new installed video card.
Jan 15, 2007 | Gigabyte GA-8N-SLI Motherboard
Intel D946GZIS Motherboard Logo
208 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
