Question about Viking VCSB423 Side by Side Refrigerator
Refrigerator trips GFI outlet
Actually VCSB420. Repaired a bad evaporator fan on the freezer side. Now fridge will run and cool for a while and then trip the GFI outlet. I have found that if I manually turn the defrost timer fridge starts and runs again for hours until it pops the GFI again. Didn't do this until after repairing fan. Local parts house thinks defrost circuit has been accidentally grounded. Have not checked yet. Can timers go bad?
  • mark zaininger Jun 22, 2007
    Refrigerator runs well when plugged into a non GFI outlet and defrosts properly. There must be a new trickle somewhere (repaired fan?) which triggers the GFI. Will try to detect leak with Ohm meter.
    President:
  • 1,462 Answers
Unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Posted on Jun 19, 2007
SOURCE:
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
FAN WORKS, BUT FRIDGE AND FREEZER NOT COOLING,COMPRESSOR KEEPS CLICKING ON AND OFF
sound like the start components are weak on the unit. you can get new start components or get a three n one control that repalces the starting components and all that you have to do is wire it up just like the diagram on the bag. or the lem could be low voltage gpoing to the refriger ator. The manufactures reccommend that you never run a refrigerator on a extenstion cord of any kind. It is also a good Idea to take the refrigerator electrical outlet off of any type of GFI receptical of any kind. you don't want to come home to a defrosted mess just because the outlet decided at that Tibme to trip.
Dec 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
GFI problem
MOST OF THE TIME THE TEMP IS NOT COLD ENGOUGH IS THERE IS NOT ENOUGH VOLTAGE GOING TO THE COMPRESOR.
YOU CAN CHECK BY PLUGING IN A VOLTAGE METOR IF YOUR NOT GETING 115 OR HIGHER THATS YOUR PROBLEM. AS FOR THE OUTLET YOU FRIG SHOULD BE ON A DEDICATED CERCIUT BUT IF NOT GET IT OFF THAT GFI CERCIUT.
Jul 05, 2008 | Frigidaire FRS23R4A Side by Side...
Viking VCSB423 Side by Side Refrigerator Logo
1,358 people viewed this question
Top Viking Refrigerators Experts
Ekse
Colin Stickland
Colin Stickland
fordexpert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
