Question about Toshiba SD-3990 DVD Player
No Disc When I try to play a DVD, it will not read the disc and only says "no disc." It has been working fine until now.
  • 3422 Answers
SOURCE: incorrect disc
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
If the problem still persists then you will have to get it repaired and thats the only solution..
Posted on Mar 20, 2008
  • 1029 Answers
SOURCE: Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Posted on May 24, 2008
SOURCE: No disc message appears
Just re-seating the flat cable, many times, didn't work for me. Instead, I very carefully cut about about 1mm off the end with a straight, smooth edge scissors. Then I plugged it in, pushed the clip down, and it worked! Be sure to cut straight, or the fine pitch contacts might not line up.
Posted on Jul 07, 2008
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
  • 53 Answers
buy new disc ray and disable the old one
Posted on Jan 10, 2009
  • 52 Answers
SOURCE: i have windows xp with a dvd burner for a drive. i
Ocasionally this can happen with DVD's. As you haven't mentioned any other problems with the burner in your computer I think there maybe a slight problem with the disc itself or that it has a lot of finger prints on it which will need to be cleaned off using a lint free soft cloth. If you look at recorded sided of the disc under a light you may see a distortion in the surface a bit like a wavy line, this could indicate a flaw in the manufacture. The reason why your dvd player can run it is often down to the quality of the laser pickup. I was once told that Pioneer dvd players are particualy good at playing a disc when other machines won't as disc manufacturer's do/did use Pioneer machines to test the quality of their discs at manufacture. I can only recomend that if your box set is new then take them back to the shop where you purchaced them from and ask for a replacement stating that one of the discs won't play on your machine.
Hope this helps,
Posted on Apr 25, 2010
0 characters
1 Points
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
We bought the Burlesque dvd and our blu-ray player cannot read the disc? The error messages 'cannot operate this disc and cannot play back this disc. This is the first dvd the blu-ray player cannot...
It's something about the Burlesque dvd. I have the same problem with mine when I try and play it on my Sony blue-ray player. It's the only disc I have that it won't play. Disc is a DVD Video disc but it will no't play in the Sony player. It plays fine on other dvd players and my computer, but not on the Sony.
Jul 16, 2011 | Sony DVD & Blu-Ray Players
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD plays well until it stutters midway thru and
If it only happens with one disc, try using a Disc Doctor/Skip Doctor on it. These instruments will repair scratches and depending on the disc, repair pinholes in the disc. Usually it's just polishing the surface of the disc. Some instruments totally resurface the disc by stripping off a thin layer of the disc to remove scratches and other damage. (Used game/music stores will do this).
Aug 29, 2009 | Panasonic DVD-RV31 DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Sep 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Toshiba SD-3990 DVD Player Logo
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
