Question about LG 42SL9000 42 in. HD-Ready LED TV
Broken screen the screen is cracked right in the center it has diffrent colors horizontally and vertically but only vertically right where the crack is in it.
  • LG Master
  • 32,281 Answers
You need to replace the LCD screen. This WEB site may have a LCD screen for your TV.
LCD screens and Inverters www.lcdparts.net
Posted on Dec 24, 2012
  • Lisa Salanoa
    Lisa Salanoa Apr 05, 2015
    Plis my LCD screen just got a crack today by my son n my daughter went n gave it a wipe n now its got tis black mark where the crack is which she thought its not gona affect cos the crack is inside the sreen..so any help with my tv plis out there?
SOURCE:
Broken screen the the lg led tv screen is cracked
Hello, the lcd portion of the screen is broken and it will have to be replaced even though the outer plastic appears undamaged. You will find that it is cheaper to replace the set than to replace the screen. Sorry for the bad news.
Sep 16, 2014 | Televison & Video
No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Mar 30, 2008 | Zenith Z32H41D TV
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
May 20, 2014 | Tablets & eReaders
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
Sep 17, 2008 | Televison & Video
Hi it's me again the gal who dropped her tv
Yes, you should still have sound, providing that you have an antenna connected and are tuned to a channel. If you have a vcr or dvd player to hook up to it try that and see if you have sound.
No sound while viewing a tuned in channel or via a vcr/dvd player is not a good sign. It may have cracked the PCB inside the tv. A cracked PCB, depending on the severity, can also be repaired.
You really won't know the severity of any internal damage until it is opened up and checked over.
Is the line on the screen Horizontal (left to right) or Vertical (up and down) and is it centered on the screen? A vertical line would indicate that it may be a cracked PCB (Printed Circuit Board).
Mar 11, 2008 | Toshiba CF36G40 36" TV
Sony Wega 29" TV screen cracked
Definitely this is due to thunder. Apart from rarely following type of problem occurs through vertical section also. Before you got the screen cracked past month or past week days you observe any rainbow color screen or single horizontal line in the center of the screen means there is a chances to crack. Unless otherwise any physical damage by any other person or the above mentions symptom there is no chances to crack the tv screen. Since it is not designed like that moreover this is SONY
Aug 27, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
LG 42SL9000 42 in. HD-Ready LED TV Logo
332 people viewed this question
Ekse
