Question about Audio Technica USB Turntable
One channel vocals drop out
On certain LP's my Audio Technica LP2D USB turntable will drop out parts of one stereo track. I can play the same album on my old Technics turntable and get the full channel so I suspect that the stylus on the new turntable may not be seating all the way into the LP groove. It does not happen on all LP's. None of the LP2D's manuals give the specific stylus replacement number (annoying) but Amazon seems to have one that looks like it. Would you suspect the stylus or some other problem? I am connected through the USB cable so it isn't any RCA jack issue.
  • 104 Answers
Yes, it is very likely the stylus. the stock needle is conical shaped like a ball point pen. You might have a tonearm that is out of alignment but usually it's the needle. It is possible it is just dust on the tip but if it occurrs in consistent areas of the record, then it is likely that the music is just too demanding for the LP2D you will either have to use your old technics which is likely better quality or you could try upgrading the stylus on your LP2D.
If you do a yahoo search for "4-211-DE-GUARD" with the quotes, the 1st result will take you to an elliptical upgrade over the stock needle. The elliptical tip will pull more info out of the grooves and into your computer for further processing.
Posted on Feb 11, 2009
Where is the audio output hole on the Audio-Technica At LP-120 USB turntable, so I can connect to my stereo system?
After reviewing some of these unit being sold on e-bay, I found some pictures that show the cable coming out of the bottom of the unit. I then went to this site
The most detailed Audio Technica AT LP120 USB Review and according to them, the cable is hard wired. This means the cable is not removable. If your unit does not have the rca cables coming out of the bottom of the unit, it may have been cut off.
Jan 03, 2018 | The Audio Players & Recorders
I've got an Audio Technica LP-1240 turntable with a Shure M97xE cartridge. I've had it for several days now, and it's been playing fine. I just got a record cleaning kit (Tonar cleaning brush with a bottle...
A damaged or worn stylus will effect all records not just one. I don't know what D4 fluid is, but if there was some still present on the record it could have got inside the cartridge and done some damage to it.
Sep 21, 2013 | Audio Players & Recorders
Sony ps x45 tone arm wont move back to the cradle?
First off, is this a Sony or an Audio Technica? There can be many mechanical issues causing this. For more information, or should you have any further questions, please visit my website at You may contact me through the website. Thank you
Aug 26, 2013 | Audio Technica AT-LP2D Turntable
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
Why can't I hear any sound when I record from my turntable conver
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Jul 03, 2009 | Audio Technica AT-LP2D Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Audio technica lp 20 usb the belt is out of place and I do not know how to put it back as it was
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Oct 11, 2008 | Audio Technica AT-PL120 Turntable
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Mar 02, 2008 | Audio Technica AT-LP2D Turntable
No matter what I do, I can't eliminate the occasional skip...
Try cleaning that lp with an anti static felt record brush, and look for either groove glide or d4 cleaner....Sounds odd, but ive ad records kept in tip top, climate controlled, and funk still gets in the groove.
Oct 29, 2007 | Audio Technica AT-LP2D Turntable
Audio Technica USB Turntable Logo
182 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
