Question about Exercise & Fitness
Pacemaster pro plus error code 20
Im receiving an erro code 20 on my treadmill
  • 6,694 Answers
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
Posted on Mar 07, 2016
4 Suggested Answers
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
Pacemaster pro plus
Usually dirt build up. Open cover and clean mecha
Jul 08, 2014 | Exercise & Fitness
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
ERROR CODE 30 ON MY PACEMASTER PRO PLUS
DescriptionErrors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.Proceed according and fix it. God bless you
Mar 23, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Getting a Bad Relay error on a PaceMaster Pro Plus. How do I repair it?
use clean it the contacts with c. cleaner buy it from some electronic store and proceed.
unplugged the machine
3) tight every connector from the relay
4) test the coil from relay for overheating or open with DVOM and replace or repair
5) see the diagram attached.
God bless you
Nov 25, 2012 | Exercise & Fitness
Looking for a user manual for a pacemaster proplus treadmill
I have a pdf of the Owners Manual for a PaceMaster Pro-Plus Treadmill. I am attempting to upload it to www.manualsonline.com, so if you still want it, hopefully they will have it soon.
May 08, 2012 | Exercise & Fitness
Mar 02, 2010 | Exercise & Fitness
Exercise & Fitness Logo
389 people viewed this question
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
