Question about ASUS T3-M2NC51PV Barebone
Powers down 3 secs after switching on - pre POST (no beep)
Built PC - switched on and entered CMOS - set boot priority to DVD then hard drive - booted from Windows XP CD - startup files successfully loaded - created HD partition - selected it and commenced formatting - got to 7% then PC hung - so forced a power down.
All subsequent attempts to boot PC fail after 3 secs without POST test and no beeps
Using AMD 5000 dual core Athlon 64 processor
  • 7 more comments
  • glenlee_john Jan 16, 2009
    Thank you for the suggestion Witchunter - have already removed graphics card (relying on on-board graphics) and have in turn disconnected hard drive and DVD also removed all but one memory chip - still powers down after 3 secs.
    ny help will be most welcome
    Thanks rockfixya - the processor fan works immediately on switch on
    Thanks gdmisp (Go to CMOS and go to auto configuration with fail safe settings. save settings and exit. or F10 and restart cd set up) - my problem is that I cannot enter CMOS - screen remains blank (no invitation to enter setup)
    Thanks Witchunter - I was confident about the processor installation - however i did not use additional thermal paste just relied on that supplied on the cooler. Would 3 secs be enough to cause shutdown for this reason do you think?
    Thank you blueetc3221 - I used the long format (partition size 120 gb) however this problem is occuring prior to POST and without being able to enter CMOS
    thank you askme - the hard drive is a new Western Digital 300 GB Caviar SATA II - however this problem is occuring pre POST test
    thanks ciraldo52 - I have virtually rebuilt the machine to no avail.
    Is it possible that this is a swith problem?
    Thank you Ronnieh49 - but I would have thought that a faulty hard drive would not prevent entry to CMOS?
    Brigadier General:
  • 5,158 Answers
Lets start with the obvious first... have you examined the power button to make sure it is not sticking. second... unplug everything including the hard drive... will it boot to the cmos ?
Third sometimes just unplugging it resetting the cmos (jumper or removing the cmos battery) will fix the issue
Robert
Posted on Jan 16, 2009
  • 535 Answers
U have to chak your hdd its has been bed sector on it so u have to do this u need to plug your hard disk in to
  • sandip panchal
    sandip panchal Jan 16, 2009
    another computer the disk go in start>run>type cmd
    press enter
    then type this command chakdsk /r
    its will fix all the bed sector from your hard disk & then try to install
    Sergeant:
  • 367 Answers
Silly question but are you installing a 64 bit version of windows?
  • 1 more comment
  • Rob Houg
    Rob Houg Jan 16, 2009
    You are correct faulty hd will not prevent access to cmos.
  • Rob Houg
    Try removing the battery from the motherboard for a few minutes with pc unplugged. Put the battery back in try booting the computer
    You can also try reseating the memory sticks.
    Or removing them completely to see where you get in the boot proccess.
    If none of these work I would start looking at proccessor fan and power supply. Faulty fan or fan not plugged in will cause restart because of over heat. (although usually it takes longer than a couple seconds)
    Check proccessor fan also check to see processor is seated correctly.
  • Rob Houg
    Sorry I skimmed through some of the responses and noticed you did see fan working for proccesor. I would check the fan in power supply as well as what the output is on the powr supply.
    President:
  • ASUS Master
  • 1,314 Answers
Hard drive? Unlikely, because it happens before post. CPU? Possibly, but very rare.
Have you tried power supply? New ones (especially those included with cases) are known for failing rather quickly. Test it with another power supply just to see if it boots up or not :c)
  • Kevin Shafer
    Kevin Shafer Jan 16, 2009
    Could it be a the switch sticking? Again, possibly....to test that, short the switch jumpers on the motherboard to turn it on and see if it does it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I suggest removing the processor and memory but leave the heatsink fan electrically connected. Power it up. If it does not shutdown within 3 seconds, most likely a defective processor. It it still shuts down, motherboard issue. Of course there is always the possibility that the motherboards will auto shutdown if it detects no processor.
Pls post back result(s). Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 435 Answers
Hi, from the description, these are the possibilities.
- Any newly installed hardware. Please disconnect and try. - Bad installation DVD/ CD. Try with another installation Disk. - Hard drive spoilt. In this case, try installating in a different partition and see.
I will update if I can think of any other possibility ... Also, set BIOS to default settings and see.
    Genius:
  • 2,920 Answers
It usually suggests theres an issue with the hard drive..you might try installing a diffent win version and see if you cant upgrade from there sometimes that will work sometimes it wont. but itsounds like a hard drive issue
  • 124 Answers
Try to remove everything and reinstal the os and boot sycence and try again try to unhook the main power block from everything and reconnect it hope this helps
    Master:
  • 416 Answers
It sounds like harddrive is bad
Is it new harddrive or used one
let me know
Good Luck
  • 15,935 Answers
Use the manufacturer's software to scan hard drive for physical platter errors. Maxtor, Seagate and Westrn Digital have software to check, and repair sectors - and is available on their respective websites for download.
Are you using the quick format, or standard format?
Sometimes drives with large partitions have problems with the long format.
Try the quick format.
If it still doesnt work, check the drive for physical errors with the software I mentioned above.
  • 3 more comments
  • blueextc3221
    blueextc3221 Jan 16, 2009
    If you cannot enter CMOS, there may be a memory module problem, or video card problem. Remove all installed memory and video card, and re-seat firmly.
  • blueextc3221
    Reset the CMOS (either remove the battery for 5 min, or your M/B may have a jumper to use)
    Incompatible memory often causes voltage problems.
    Your model #s of installed components (M/B & memory module) would be helpful. otherwise we are grasping at straws.
  • blueextc3221
    you can also remove the battery and re-try. If the system works, your battery needs replacing.
  • blueextc3221
    Have you disconnected the drive to try and enter BIOS?
  • blueextc3221
    The POST process checks the basic system functions before attempting to load an o/s. It checks RAM, Processor, drives, system interface, etc. If POST fails, the system will normally halt and may produce a series of beeps from the internal speaker which can help indicate the cause of the problem. Is your internal speaker hooked up?
  • 66 Answers
Go to CMOS and go to auto configuration with fail safe settings. save settings and exit. or F10 and restart cd set up .
  • David McCreery
    David McCreery Jan 16, 2009
    Ok uplug all stuff on pc . If you cannot enter CMOS, there memory module problem, or video card problem. Remove all installed memory and , and re-seat firmly.Then try to boot with system cd an a reconfigure.Then go back to in stall os.
  • David McCreery
    The only hardware that can be faulty at this point are motherboard or onboard drivers power supply jumpers on motherboard or processor.
  • 679 Answers
Check out the processor fan.
  • 1 more comment
  • rockfixya
    rockfixya Jan 16, 2009
    Ok.. do some steps1. First of all reset BIOS to default setting and then try to boot. (if you cant able to go in BIOS setting that means there is some BIOS virus in BIOS)
    2. Try to boot your system from another bootable CD/DVD.
    If the solution not works for the problem that means there is some problem in hard drive (HDD) of your system.
  • rockfixya
    scan your BIOS with any new updated antivirus.
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
    Thanks for using FixYa.
  • 98 Answers
What you can try is removing all of your add-on cards, leaving only main components in the system. This way, if the computer boots, you will rule out all the main components as faulty.
Next, try adding add-on components one by one and see which one hangs the system.
  • 2 more comments
  • Nikola Malesevic
    Nikola Malesevic Jan 16, 2009
    You could try putting the other memory module instead of the current one, maybe the problem is there.
    This behavior might occur if processor temperature is too high, so motherboard shuts down the system. Are you sure processor is well mounted with thermal paste and has working cooler on it?
  • Nikola Malesevic
    Try removing memory modules as well. If it doesn't beep, memory is just fine. Then the only things that are left are procesorr and motherboard.
    One more thing: You can remove your CMOS battery for 30 seconds - this way, BIOS will reset. Put it back and try to boot. There is a way to clear CMOS settings via jumper, but that depends on the motherboard.
  • Nikola Malesevic
    First try the methods of clearing CMOS.
    If it doesn't help, then it might just be that processor is too hot.
    Leave it be for an hour or two in some chilly place, then try to boot it. If it shows you boot screen, or at least lives for 15 seconds - cooling is the problem.
    Of course, you will have to solve this as soon as possible to avoid burning the processor.
  • Nikola Malesevic
    Please disregard all of the comments stating the faulty drive or entering BIOS.
    Also pay attention to Benimur's post.
    The only hardware that can be faulty at this point are motherboard or processor.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
I want to boot from DVD. In order to fix a bootmgr problem on a SSD. In spite of using same W7 disk as I used for installing, the PC will not boot from DVD.
Recheck data and power cables. There's two places to set boot order: the one called "Boot Order" and there's usually another menu called "Drive Order" that will list the priority of the drives on the SATA chain.
Also, since you reset CMOS, is it possible that you might have to change SATA profile from IDE to AHCI?
Feb 26, 2014 | MSI B85-G41 PC MATE Intel B85 Motherboard...
How do I set the jumpers to make it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 10, 2011 | Hitachi Computers & Internet
Cannot install windows xp after formating
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this or if i have misunderstood the problem
post a reply
hope this helps you
Sep 06, 2011 | Toshiba MK3276GSX 25 inch 320GB 5400RPM...
I have 2 hard drives i want to make one master and 1 slave model HDSJ oth 7200 rpm
if you need more help with this post a reply
Hope this helps
Aug 18, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
Cd Group Boot Priority not installed
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Mar 27, 2011 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
In nova net pc with intel D945GCLF Mother board , it does not boot the system with windows, and want to flash the bios , its not supporting with usb boot, cd,dvd booting ? , then how we install windows in...
while booting up it must be giving you an option to enter the cmos setup with hitting either f8 key or del key or f10 key. Just hit the key at the appropriate time and enter the advance setup in the cmos setup and go to boot devices and select the priority you wish. In some cases the hard drive and cd rom have jumper settings for putting them in master and slave mode. just read on the drive label and set your cd rom to master and your hdd to slave and you will be able to boot through cd and instal windows.
Dec 26, 2010 | Intel Computers & Internet
I have a gateway 500xl that the previous owner reformatted the harddrive wiping the xp operating system. I've upgraded the ram but without an op system I cannot turn the machine on. I need to install...
Hi there.
For this process you will need:
1) The hard drive you want the operating system on.
2) The operating system disk (Windows, Linux, etc, depending on your os choice)
3) A CD/DVD drive.
Firstly you will need to enter the BIOS on startup by pressing the Delete key repeatedly as your system starts up. In the BIOS you need to locate the boot disk priority section. You need to set priority 1 to your CD/DVD drive and priority 2 to the hard drive you wish to install the operating system to. Once this is done save changes to the BIOS and exit. Your system should now restart and on boot-up it should display a message "Insert bootable disk" or something like that. This is where you put in the operating systems install disk into your CD/DVD drive. Once it is in restart your system. Now your PC should boot up and ask you to press "Enter" to boot form the CD/DVD. Press enter to proceed. The setup should now begin, just follow the steps given by the setup wizard. Once the setup is finished and your PC reboots and on startup you get the same message about pressing "Enter" to begin setup just do nothing. Your PC should then switch automatically to your newly installed operating system and boot into it. Once your PC is fully booted into your operating system of choice remove the setup disk.
Slasher_X
Nov 13, 2010 | Gateway 500XL PC Desktop
Dell GX110 not booting from CD Problem
Have you set BIOS to Boot from the CD/DVD? If not please do that.
Mar 29, 2010 | Dell OptiPlex GX110 PC Desktop
ASUS T3-M2NC51PV Barebone Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
