Question about JVC BR-DV600U Mini DV VCR
JVC BR-DV6000 Print to tape problem
I work off a Mac and when I go to print to tape on a DVCAM tape, the audio cuts off, but when a mini DV tape is used, it lays perfectly. Now the big mystery is that the tape deck lays perfectly off of a newer computer. Another thing is that when you plug in earphones to hear the audio while it lays, it sounds fine. Can anyone help?
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: fire connection
Do you have its Service Manaul to check any hardware problem in unit?
Posted on Aug 03, 2008
mistersony
  • 320 Answers
SOURCE: JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Posted on Nov 08, 2008
I HAVE A PROBLEM TO RECORD A DVD TO DVCAM MINI DV, JVC - BR-DV3000
If it is a commercial Dvd it probably has copy protection.
Dec 30, 2014 | JVC Video Cameras
JVC BR-DV3000 Mini DV-DVCAM driver
Try JVC first but what do you expect to find a driver for?
Jun 13, 2012 | JVC BR-DV3000U DV/Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
With MiniDV tapes, the DVCam indicator ignites and the reading becomes jerked.
It could be several things causing your problem. The video head may be worn, the tape guides may be out of alignment or you may have a mechanism problem keeping the tape from wrapping securely around the rotating drum. If you can use an oscilloscope, you should check the RF signal coming off the drum test point to see if it is clean, or if half the signal is missing (bad drum or video head) or not smooth (guides out of adjustment).
Nov 08, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Aug 22, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Fire connection
Aug 03, 2008 | Sony DSR-1500 Mini DV VCR
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Won't play DVCAM, will play Mini DV
it is probably matter of dirty guide so the timecode stop reading try a wet head cleaning tape to play it there regards please don't forget to rate ,thx
Feb 20, 2007 | Sony DSR-45P DV / Mini DV VCR
JVC BR-DV600U Mini DV VCR Logo
107 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
