Question about Rio Forge Sport Digital Media Player
Rio Forge 256Mb Mp3 Player
When I turn it on a message appears "Internal memory unknown format. Attach usb and reformat" What can I do??
  • 3 more comments
  • Fernando Rendon Jun 19, 2007
    Dear Lolita I've done that several times but when i plug the usb cable appears the following FORMATING, then READING, and finaly it stays in IDLE. And something else when I plug the mp3 player i get two Rio units in my pc one says can read due to an i/o error and the other one says there is no disk, PLEASE HELP!!!!!
  • vickijo Feb 28, 2008
    I have the EXACT same problem. Haven't figured out how to format since it seems my pc doesn't communicate via the usb. I've had this mp3 for about three years and this is a new one!
    Internal format unknown insert usb and reforemat
  • janetm_jones Jun 30, 2008
    Yes, I have the same problem. I tried to reload the software but the software exe says "No players could be found".
    Success - it's working. It is as Mantraguy described in his posting of March 08 but when you switch it on you must already be holding down the menu button. Then you get the upgrader and can do the firmware install. Thanks guys
I had the same problem and, after scouring the internet in search of a solution, found nothing. So I started messing around with things. About 5 minutes ago I came up with something that worked for me! I'm still in 'testing' mode but it's playing some ACDC now so I'm happy. ;-)
My first step was to download a firmware 'update'. I'm not sure if it's newer or older than the firmware that I already had in there, but it works so what the heck. It's version 1.16 and is available for download here:
http://www.opendrivers.com/downloaddriverlink.php
Filename is 'RioForgeFlash_116.exe'
To update the firmware, I connected the player via the USB cable. It will power itself up automatically - make sure you have a fresh set of batteries in it. Once it powers up, turn it off but leave it plugged in via USB. Then, power it up again but press and hold the mode button (the small button on the face, to the left of the main navigation buttons. It's the one you use to select different play modes etc.). It will power up and display 'UPGRADER'. From this mode, run the udate file (RioForgeFlash_116.exe); it will update the firmware in the Forge.
Once completed, my Forge interacted normally with the Rio Music Manager and I was able to upload music to it again. I did lose all the music that was in there and on the storage card, but that's better than having a useless MP3 player!
Best of luck!
Posted on Mar 12, 2008
Go to the Rio support page. http://www.rioaudio.com/support/rio/
Using XP the following link should get you the driver you need.
http://www.rioaudio.com/support/rio/downloads/Forge/RioForge_firmware_133.exe
Driver updates.net looks like a ruse to get you to install something... Uhm, other.
To update the firmware, I connected the player via the USB cable. It will power itself up automatically - make sure you have a fresh set of batteries in it. Once it powers up, turn it off but leave it plugged in via USB. Then, power it up again but press and hold the mode button (the small button on the face, to the left of the main navigation buttons. It's the one you use to select different play modes etc.). It will power up and display 'UPGRADER'. From this mode, run the udate file (RioForgeFlash_1.33.exe); it will update the firmware in the Forge.
You may have lost your files but load em back up and rock. PS: I don't use Rio Manager. I just drop the files on the drive. Never been impressed by these MP3 file manager software.
Piece of cake. Good luck..... ROCK IT.
Posted on Nov 18, 2008
THANKS!!!!
Posted on Sep 18, 2008
I followed all the suggestions from Mantraguy. Once I had downloaded the driver the suggestion from janetm_jones was critical to get the updrader on my Rio Forge. Once the grader came up I ran the new driver file. I then had to unplug my Rio Forge from the USB Cable. When the Rio Forge rebooted the new file formated on my Rio Forge and the Rio Forge Manager would recognize it and could download.
Now it is working fine...confusing...
janetm_jones,
Posted on Aug 23, 2008
I had the same error Internal format unknown insert usb and reforemat, but mantraguy's solution posted Mar 12 worked perfectly, THANK YOU!!! Also, found that if your RioForge is not turning on at all: take the battery out for 20 minutes, put it back in, turn it on, and then follow mantraguy's solution (I kept my memory card out, so my Audible books were still there when I put it back in, but my stored bookmarks were gone).
Posted on May 03, 2008
The solution posted by Mantraguy worked! Thanks! I was just about to throw my Rio in the trash!
Posted on Apr 02, 2008
I’m totally lost.. I’m having the same problem… when I connect my Rio…. Once I see the “drive” I right click and click on Format… and nothing happen… nothing comes up for me to do the Fat32.. I’m also looking for “michelle” but I can’t find her… according to what “Gust” said.. he/she got it to work.. Please help…
Posted on Mar 05, 2008
Http://forums-riovolution.com/index.php?showtopic=11630&st=15
I did what "michelle" said (scroll down and look for that user name) and it finally worked!
Posted on Dec 03, 2007
Hi, I've got the exact same problem.
I tried formating it, but when I select the player and click on format, nothing happens. There doesn't pop up a new window, nothing... what can I do??
Posted on Oct 25, 2007
  • 385 Answers
Hi, Plug the mp3 player into the PC via the usb cable and when it loads as a drive in MY COMPUTER, right click on it and select format. Choose the FAT filesystem to format and your message should disappear. Let me know if this solves it. Thanks, Lolita
Posted on Jun 19, 2007
  • Rona  Heredia
    Rona Heredia Jun 19, 2007
    Ok. Can you format it from within the options of the mp3 player?
3 Suggested Answers
SOURCE:
johnychel
  • 796 Answers
SOURCE: Rio Forge 256Mb Mp3 Player
was there any cd given along with the purchase of this player???????
Posted on Feb 28, 2008
mattozan
  • 555 Answers
Unless you are using Windows98, your computer should have the drivers it needs to recognize your player.
You can try re-installing the latest Rio software.
Plug the mp3 player into your PC via the USB cable. When it loads as a drive in MY COMPUTER, right click on it and select "Format."
Choose the "FAT" file system to format. This will erase and reformat your Rio Forge memory.
Need softvare for rio forge 256mb digital media player
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Sep 25, 2012 | Rio Forge Sport Digital Media Player
Feb 28, 2008 | Rio Forge Sport Digital Media Player
Rio Forge 256 MB
Try hooking the player to your computer and reformat the memory in the player. Just like you would format a disk.
Kenny
Mar 26, 2008 | Rio Forge Sprot MP3 Player
2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Nov 19, 2007 | Rio Forge Sport Digital Media Player
RIO FORGE 256
I had exactly same trouble - at least twice..
One time a battery switch and drain for at least 10 min fixed it.
another time I reinstalled firmware...
No big deal..
Nov 11, 2007 | Rio Forge Sport Digital Media Player
Rio 512 mp3 player
You need to connect the Rio to a PC and then use the Windows Explorer format disk feature to reformat the Forge's flash memory as a FAT32 partition.
Sep 08, 2007 | Rio Forge Sport Digital Media Player
Turn it on holding the MENU button, connect the usb cable and update the firmware that u can download from www.rioaudio.com, that will fix it.
Dec 15, 2006 | Rio Forge Sport Digital Media Player
Rio forge 256 MB mp3 player
This happened to my player also. To fix it, you have to go to the rio website and download the most recent firmware for whatever model mp3 player you have. I went to: http://www.digitalnetworksna.com/support/rio/product.asp?model=265&SKU=90260558) Next install. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and follow the directions and it will see your player and upgrade the firmware (yes, even if it's the same firmware version.) You'll have to run the .exe file to get the upgrades onto your player. Unplug the player and it should be like new!
Oct 28, 2006 | Rio Forge Sport Digital Media Player
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Oct 12, 2006 | Rio Forge Sport Digital Media Player
Formatting the player memory
This process worked for my m25:
1. Download v1.11 firmware file from http://broadband.motorola.com/consumers/support/default.asp?supportSection=DigitalAudio
2. With USB cable disconnected, turn off the m25.
3. Press Power while holding Menu button until UPGRADE is shown.
4. Connect m25 via USB cable.
5. Run the firmware downloaded in step 1.
6. Disconnect the USB cable, and the m25 should start a normal.
Dec 24, 2005 | Motorola Mobility M25 MP3 Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
1,083 people viewed this question
Top Rio Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
