Question about Texas Instruments TI-83 Plus Calculator
Screen is dark and won't lighten with lighten button
We have tried using the lighten buttons and changing the batteries.
    Problem Solver:
  • 15 Answers
Try replacing the screen
Posted on Jan 17, 2009
How do i get my screen to lighten up it to dark
Have you tried using the F2 button?
Else go to system settings > displays, there you can adjust brightness as well.
Also you can switch off the auto brightness there. 25262036-egkukr40z00e2y5uxj02hrxw-1-0.png
Oct 30, 2014 | Apple Computers & Internet
Dark blue screen can't see display.
With the calculator on, hold the ON button and press the - button to lighten the display. If you go too far, use ON and + to darken the screen.
Aug 28, 2011 | HP 48G Graphic Calculator
My ti-84 se plus has batteries that work, but it isn't turning on do you know why?
Personally I do not know why because I do not lnow what the calculator went through. However, if the calculator was working correctly but after you changed the batteries it does not seem to come alive when you press the ON button, then I may have an idea. Here it is.
After you change batteries, the screen may become too dim or too dark. For your case it may be too dimm.
To darken the screen, follow the procedure below.
1. Press the [2nd] key and release it.
2. Press the UpArrow and hold pressure on it (to darken screen) or DownArrow to lighten screen.
As you keep the UpArrow held down, you will see somes numbers at the top right corner of the screen. You mifgt first see a 2 or a 3, then the next number and it keep increasingAfter a while it becomes too dark to see anything.
To lighten the screen
2. Press the and hold the DownArrow
As you keep the DownArrow held down, you will see somes numbers at the top right corner of the screen. You mifgt first see a 8 or 7 , then the next number and it keeps decreasing.
Release the Arrow keys when the screen contrast is to your liking.
If you overshoot your intended screen contrast you can revert the process by reverting the procedure.
Aug 27, 2011 | Texas Instruments TI-84 Plus Calculator
My screen for my TI-83 is turning black and I can't get it off
How to Change the Brightness of the Display
To darken the display, press the yellow 2nd button and then press and hold down the Up-Arrow button located in the upper right section of the keypad. Release the Up-Arrow button when the display has reached the desired level of darkness.
To lighten the display, press the yellow 2nd button and then press and hold down the Down-Arrow button. Release the Down-Arrow button when the display has reached the desired level of lightness.
As you go through this process, a number will appear at the top right corner of the display. If this number is 7 or higher when your screen reaches the desired level of brightness, then your batteries are getting low and may need replacing soon. This number will be approximately 3 or 4 for new batteries.
Jun 17, 2011 | Texas Instruments TI-86 Calculator
My TI-81 screen is too dark. Is there any way to lighten the resolution on the screen? Thanks.
Hold the [2nd] button down while tapping the up or down arrows. This will change your contrast.
Jun 08, 2011 | Texas Instruments TI-81 Calculator
My ti - 83 hasn't been used in a while, placed new batteries in it and all i get is dark screen.....it won't even turn off......there is just a dark screen......any ideas what causing this and how to fix...
The most probable cause (at least I hope so) is that the screen got too dark after you changed the batteries. It is a common occurrence: Screen becomes too dark or too light.
To adjust the screen contrast:
  1. Press ^2nd key and release it.
  2. Press and HOLD the DownArrow key until screen lightens to your taste.
Mar 09, 2010 | Texas Instruments TI-83 Plus Calculator
The calculator crashed two times several days ago while I was using it. It worked fine the following day, but after that the screen became very dark. So dark that I need a flash light shining at it to see....
I will address one part of the question only: I will avoid the speculations.
How to change the screen contrast
  1. (TI-Nspire with native keyboard): With the TI-Nspire keyboard in place,
  2. Press the ON button to turn calculator ON.
  3. Press and HOLD the Control key [CTRL]
  4. Press [+] to darken the screen
  5. Press [-] to lighten the screen (Your case)
  6. Stop when contrast is adequate.
  • TI-Nspire with TI84PLUS keyboard: With the TI84PLUS keyboard in place
  • Press the ON button to turn calculator ON
  • Pres the [2nd] key and RELEASE it
  • Press the [UpArrow] of the NavPad to darken
  • Press
Feb 15, 2010 | Texas Instruments TI-Nspire Graphic...
My texas instruments ti-86 is dark all the time, help me please
After changing the batteries the calculator is restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything or., as in your case too dark.
To lighten screen
Press [2nd] key and release it.
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Dec 04, 2009 | Texas Instruments TI-86 Calculator
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
To lighten screen
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
Screen is very dark
Try 2nd and all the way down arrow
Jan 21, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-83 Plus Calculator Logo
304 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
