Question about Apex Digital Digitrex DSC-3000 Digital Camera
With new batteries already put in--no power
I put new batteries in and new memory card in. When I attempt to turn it on I get a small burst of power (green light goes on and aLCD screen flashes on) then nothing. I then open the battery door and can repeat that process again.
My son got this camera over a year ago (not new) and it came with this problem. He just put the camera aside. I am trying to see if it is salvageable or not fixable.
  • Anonymous Feb 09, 2009
    i have the same problem tried normal and rechargeable battery and nothing
  • 4 Answers
Are you using rechargeable batteries, and have tried lots of different batteries? Also, sometimes rechargeable batteries fresh out of the package can be dead or have very little juice. Just a thought...Hard to say that's it though if you were having the same thing happen before...
Posted on Jan 16, 2009
I have put new batteries in and a new memory card I turn on the power switch and it goes on and off straight away, what am I doing wrong,?LIz
First thought - is the memory card compatible with the camera ? Many cameras have a limit to the memory card capacity they can use.
Oct 01, 2016 | Pentax Optio I-10 12.1mp Digital Camera...
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My Nikon Coolpix S8000 will not turn on. I started using it for the first time this morning and took about six pictures with it, then I removed the memory card in order to upload the pictures onto my...
Make sure you insert memory card correctly, when it is fitted into the memory card terminal it give clicking sound. Second thing you can check battery, Direction of your battery might be wrong (+,_), Check out and put it again. Load new or fully charged battery. Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
Else your camera need to be repaired.
Thanks...!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Nikon COOLPIX S8000 Digital Camera
AFTER INSERTED A NEW BATTERIES IN THE SCREEN SHOWS CARD LOCKED, HOW I CAN FIX THAT
Try taking out your batteries and then taking out your memory card. In memory card you can see a small button at the side you need to slide that to unlock your memory card. Put back in batteries and memory card. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
Mar 29, 2010 | Canon Powershot SX110 IS Digital Camera...
Camera will not turn on. Already replaced batteries.
as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
One more resion is images in memory card,firstly download ths images in system and formate the card.
Thanks,
Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
I have a new Toshiba NB205 netbook and I want to replace the memory card with a Crucial 2GB card. I removed the back panel (1 small Phillips screw) and I see the 1GB card, but I do not know how to remove...
Steps to perform it.
1. remove the battery pack from your laptop
2. In perfect case you would need ground wire put on you hands.
3. move latches from each side of the memory to side.
4.then it should move up remove it.
5. Install new memory
Please see movie on youtube
Sep 24, 2009 | Computers & Internet
My olympus camedia d-540ZOOM writes " write protect" on its screen... so, I can't take pictures, can't edit them.I can't even move the pictures to a pc inserting the memory card directly...
Take your memory card out and move the tiny plastic switch on it to "unlock" or whatever it says. If that doesn't help, try another card. If that still doesn't help, come back and we'll try something else!
Sep 03, 2009 | Olympus Camedia D-540 Zoom Digital Camera
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
Apex Digital Digitrex DSC-3000 Digital Camera Logo
85 people viewed this question
Top Apex Digital Cameras Experts
Mohammad Abumuailek
Mohammad Abumuailek
Steve
Tony Parsons
Tony Parsons
Are you an Apex Digital Camera Expert? Answer questions, earn points and help others
