Question about HP Photosmart C6180 All-In-One InkJet Printer
Omnipage 16 is not scanning from Microsoft Word with HP Photosmar
I have tried everything to get drivers, or re-install both Omnipage 16 and the HP Photosmart 5180 All-in-One Printer...Instead of getting an instant scan when I need it I get a window (load files) Look in- My Documents and lists those files but no scan, what am I missing? I have even gone as far as to reload the entire Windows program with no result...is there a patch, a driver, a fix, a website, an adjustment I must make, what? After getting nuance on the phone for three hours and having them run me around and do nothing I am beginning to think that they just stole my money and do not give a rip...
    Champion:
  • 203 Answers
Just go on the HP suportpage and you should be able to find your driver's    www.hpsuport.com. or try to find the detection of you printer on the suport page.
Posted on Jan 16, 2009
OmniPage Professional 16 fails to launch
uninstall the program, reboot and then reinstall it following the instructions and on-scree commands and prompts. if the result is the same, maybe consider changing the version of your os, maybe your os somewhat conflicts with the program. try using oem os'
Jun 02, 2010 | ScanSoft Nuance OmniPage 16 Professional...
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
How to scan using canon pixma mp150
I hoe it helps!!!
Scanner wouldn't work. Uninstalled HP Photosmar C4200 series. Now can't reinstall it. Keep getting a fatal error.
maybe the file is corrupted. try to uninstall the driver or by manually delete the file from program files..then re-install the driver..
Nov 29, 2008 | HP Computers & Internet
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
HP Driver Installation Problem "fatal error scan msi" + "error 1395"
Some programs on Vista require you to be logged on as Admin to run them correctly ... Who knows why ? Only B G could answer such a question.
This applies to the majority of 3rd party programs as well, although i'm not entirely sure why this would happen with a printer driver, but it may be worth a shot eh ?
Jan 13, 2008 | Office Equipment & Supplies
Communication problem?
Dear CrysC,
I had the same problem with my HP Officejet J5780. I just got it to work with a different paper size.
Don't ask me why this worked, but it did, so I guess that's all that matters.
In Omnipage, I went under the "Tools" menu and clicked on "Options." I then clicked on the tab, "Scanner." I changed the paper size to what I wanted (A 4). I then clicked on "Setup." Despite its recommendations not to do so, I reinstalled my scanner.
After the reinstall, it is now scanning the new paper size.
I hope that I don't have to do this everytime I scan a new paper size...
Douglas1966
Aug 28, 2007 | Canon DR-2580C Path-Through Scanner
HP Photosmart C6180 All-In-One InkJet Printer Logo
172 people viewed this question
Ben Johnson
