Question about Alesis Sr 16 Stereo Drum Machine
The tempo indicated on the alesis sr16 is inaccurate
Alesis tempo 120bpm corresponds to cubase metronome 120.76bpm.Can this be rectified?
  • bob_the_bug Jan 28, 2009
    i have exactly the same problem using ableton live. I think the ableton metrone is "right" and the SR-16 wrong because ableton and my KORG kaossilator are in sync... does anyone have a fix?
    New Friend:
How can i change the tempo on song compose, for example step 01 tempo 60 and step 02 tempo 120??
Thanks.
Posted on Jan 18, 2010
  • ecj770 Jan 18, 2010
    How can i change the tempo on song composing? for example step 01 - tempo 60 and step 02 - tempo 120??
    Thanks.
SOURCE:
How do I reinstall preset patterns
According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
Output section of PCB appears a bit fried as there is no sound output and there is a hint of burnt electronics. Rest of the SR16 works fine. I believe someone reversed the audio cable connections which...
This is your best bet:http://www.alesis.com/content1024 It will be hard to find a schematic. Here is another link:http://www.ionet.net/~tslade/sr16.htm
Aug 25, 2010 | Alesis Sr 16 Stereo Drum Machine
I can't find a rotary pot for alesis sr16
Try WD Greenhill.com. They were really helpful when I've needed hard to find parts for synthesizers. Let me know if this helps.
Jan 18, 2010 | Alesis Sr 16 Stereo Drum Machine
How can I put a walz beat in the Alesis
Page 59 Odd time signatures of the owners manual explains how to do this. Type Alesis SR16 manual into Google and you can download a copy from media.zzsounds.com Please rate this if it helps. You can also download documentation here:http://www.alesis.com/sr16 under DOCS and Downloads
Oct 29, 2009 | Alesis Sr 16 Stereo Drum Machine
Not [email protected] full pwr.I just got a new power supply I plugged it in the wall , in a short time the pwr supply got hot.. is there a way to reset it?
Sounds like you got an incorrect power supply OR the SR16 has a failure creating too much load.
The power supply should be a 9VAC at 1 amp (1000 ma)
The power supply MAY get warm to the touch but should not get real hot.
Without the SR16 pluged onto the power supply it should barely get warm. If the SR16 doesn't work, then it probably has an internal failure... LIKELY the internal rectifier filter combination.
Oct 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Question on the start /stop feature and saving tempo information
As I read the manual, the tempo is saved with the SONG.
Starting and stopping rhythm SHOULD always start at the begining of the song. This is on page 20 of your manual. The manual is available online if you don't have one.
Jun 12, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
505 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Harrie
Phil Whisenant
Phil Whisenant
Are you an Alesis Music Expert? Answer questions, earn points and help others
