Question about Hamilton Beach Water Cooler with Storage Cabinet
Water cooler won't stop running
My water cooler won't stop running. It will cool the the water but it won't shut off after.What do you thin
k is the problem?
  • Anonymous Jan 20, 2009
    Mine is doing the same thing. I believe it must be a thermostat. Will the co.help? I think it is a defective part. I know of a few people that have had same problem and discarded the unit. I turn mine off and just don't have cold water. Please help
  • Marion Empson Mar 20, 2009
    i have a munro water cooler is there a switch to switch on as plugs in but wont lite up
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Posted on Apr 24, 2008
SOURCE: Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Posted on Nov 05, 2008
SOURCE: freezer and cooler stopped cooling as much, meat
excess codensation and some freezing in refrigerator
Posted on Jul 10, 2009
Sea Breeze
  • 4636 Answers
SOURCE: Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
Posted on Mar 17, 2010
SOURCE: Our Hamilton beach water cooler makes a constant
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Posted on Feb 19, 2011
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
Feb 15, 2011 | Hamilton Beach Water Cooler with Storage...
How can I repair it if the cooler will no longer cool?
I am looking to purchase this 87307. Do you still have it? My e-mail is vmd011@hotmail.com
Jun 01, 2010 | Hamilton Beach Water Cooler with Storage...
Mar 17, 2010 | Hamilton Beach Water Cooler with Storage...
Cold water never quits trying to cool water. runs
Hello, this is going to be a bad thermostat. This is located behind the grill in the back. It has 2 electrical wires and a metal wire that goes to the tank, you should replace it. Hope this helps! Mike
Oct 30, 2009 | Hamilton Beach Water Cooler with Storage...
After pugging in the water cooler, the fan starts running, all good water is cold but the fan never turns off. is this normal.
Yes except if it has a temperature control but would cut off only when it has reached the desired temperature, and water coolers are not the efficiency compared to a heat pump or air-conditioning, it only cools the air with the water running over the pads so whatever the temperature of the water is that’s the temperature the cooler will cool the air to. so in theroy it will only drop the temprature 10 to 15 degrees.
Sep 14, 2009 | Hamilton Beach Water Cooler with Storage...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Won't Stop Cooling
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
124 people viewed this question
Top Hamilton Beach Water Coolers Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Hamilton Beach Water Cooler Expert? Answer questions, earn points and help others
