Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitusbishi WS65813 blinking green light
I understand you may have the solution. I did the obvious stuff...unplug-wait-plug in and try again...reset button on front...combinations of these. My email address is prophead at digital dot net. I will certainly rank you if you have the fix. Oh yeah...thanks too.
prophead
  • likeparty Jan 24, 2009
    Techlore has a complete guide posted on their side in pdf that fully explains the fix with pictures, replacement part numbers, etc. Today is the day...the caps are here from Digikey, the desoldering equipment is ready, solder and soldering iron too. Wish me luck. The part about contacting Mitsubishi will help if the cap replacement fix doesn't work. By the way...the caps are 1000uF, 35V and MUST be replaced with 105C versions...not the 85C versions you can find at Radio Shack.
  • likeparty Jan 25, 2009
    I replaced the caps yesterday and did the victory dance. The set worked for an hour then the blinking green light of death returned. I don't know what to do beside try the fix again. Do you have any other ideas? Sending the chassis sounds like a major deal.
    Problem Solver:
  • 10 Answers
You have a defective power supply and/or DM board, usualy are bad caps 1000 uf 16v, if after replacing all caps the problem persist you will need to contact mistsubishi and send the chassis for repair.
Posted on Jan 23, 2009
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
I have a green flashing light and my tv won't turn on.
This is cause of a power interuption. Try unpluging the TV from the wall, and waiting several min. Then plug it back up, wait serveral min again and the green light should stop blinking.Then turn it on.
Jan 08, 2011 | Mitsubishi WS-65809 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Mitsubishi ws-65515 tv green light blinks constantly after power failure.
I UNPLUG IT AND WAIT A FEW MINUTES...THEN I PLUG IN THE POWER AGAIN AND IT WORKS
Jun 11, 2008 | Mitsubishi WS-65515 65" TV
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
