Question about Lexmark JetPrinter Z11 InkJet Color Printer
Lexmark Z11 won't work
Hello, I have a notebook with Vista and Lexmark Z11. I bought a suitable cord for connecting them together, installed the drivers, but the printer won't print the test page, the error appears in the window with tasks for printing. But the control panel shows the installed printer and says "Ready to work", and the printed doesn't giva any sound.
Please help me what to do.
  • 1 more comment
  • fruttis Jan 16, 2009
    Thank you for a fast answer, I tried to do as you said, but failed again. I deleted the printer from the control panel, then installed the driver again, then restarted the PC, tried to print a test page and again an error :(
    At the same time I see that the printer react to the restarting of the system, he begins to roll and throw out the paper. But doesn't print.
    What else can I do?
    The matter is that the device manager doesn't display the printers at all. There are no printers in it's list of devices. How can it be if the installation of the printer went successfully?
    How can it be that the device manager doesn't display the printer in the list of devices and at the same time control panel shows that the printer is succesfully installed? Where exactly is the problem?
    Sergeant:
  • 367 Answers
Remove the software for the printer through ad remove programs in control panel
Then keep unit unplugged from usb. Install the device drivers then plug unit in when software asks or after it requests a reboot.
Posted on Jan 16, 2009
  • 2 more comments
  • Rob Houg
    Rob Houg Jan 16, 2009
    Did you actually remove the printer software from the computer. make sure the printer was unplugged reinstall the drivers with printer unplugged then plug in printer after the installation proccess requests it
  • Rob Houg
    Try removing the printer software by using ad remove. If that doesn't work right click with mouse button on my computer.
    1. Right click on my computer
    2. select properties
    3.) Hardware
    4.)Then select device manager
    5.) Remove the printer and all printers from this location also remove all usb drivers reboot the pc with printer unplugged from device. By remove I mean Uninstall. You can do this by right clicking on the specific item in the list.
    Then do the software installation without printer attached. when asked plug in printer.
    This should work unless there is somthing physically wrong with the printer.
  • Rob Houg
    Hopefully you can see this picture. once removed it will take quite a bit for your pc to boot as it reinstalls the usb items etc.
  • Rob Houg
    Rob Houg Jan 19, 2009
    Did you install the printer software before plugging in usb cable? Some printer require you install software then connect printer to machine.
I need to get instructions on how to properly line up the print heads after installing a new cartridge on my printer, a Lexmark Z11 color printer. Thanks.
In XP - Maybe in Vista and 7 too.
Start
Control Panel
Printer and Fax
Highlight your printer (Z11)
RIGHT click it
Select Properties
Print test page
Follow directions
Dec 22, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Printer
Hello there.
Click here to download the setup file for Windows 2000 or XP. Alternatively click here for the Windows 2000 only driver.
Hope this helps.
Jun 24, 2008 | Lexmark JetPrinter Z11 InkJet Color...
We have windows vista and when we tried to install compac IJ300 it only goes up to windows 98 - can we install that using vista???
I found this solution on another website, I suggest you give it a try.
Everything works fine since I installed Vista except for my printer a Compaq IJ300 which is a Lexmark Z11 in disguise. I installed the driver for the regular Z11 through the "Add Printer " but had problems.
Went to Lexmark site - downloaded drivers for Z11 Series ColorFine- working perfectly. So far I have no other problems with vista.
Aug 25, 2009 | Compaq Inkjet Ij300 Printer
Lexmark z11 vista usb drivers
www.lexmark.com go to support and enter your printer information and search for VISTA Drivers
Jun 20, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I have a Windows Vista and wonder if my Lexmark Z11 will work on it. I no longer have the C-D Rom. Is it possible that I could get a diskette?
Z11 drivers are available here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Vista drivers are not listed on the site. You can try the XP drivers to see if they work or contact live support at the link above and see if they have any.
Sep 09, 2008 | Lexmark Office Equipment & Supplies
Can't install my lexmark z11 printer to my computer that is useing windows vista
If you are running vista Please note that , Lexmark does not have a driver for this printer which is supported by Windows Vista.
but people have reported success using the Windows 2000 /xp driver on Vista.
check this lexmark site to see the list of printers supported on vista http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_924205346_924205387_en,00.html
Sep 07, 2008 | Lexmark Office Equipment & Supplies
Reinstall printer
You can download your driver here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z11+Color+Jetprinter
If you have Vista:
Please note: At this time, Lexmark does not have a driver for this printer which is supported by Windows Vista.
However, people have reported success using the Windows 2000 driver on Vista.
Feb 11, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Need cord to connect printer to comuter for Lexmark Z11 printer
You likely need a USB cable with an 'A' connection on one end and a 'B' connection on the other end. They can be found at stores like Best Buy, Office Max, Staples etc. If the computer you are trying to connect the printer to doesn't have any USB ports, then you will have to add a USB card in one of your computer's expansion slots to allow the printer to work.
Open Questions:
I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark JetPrinter Z11 InkJet Color Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
