Question about Toshiba Satellite M35X-S349 Notebook
System Restore My Toshiba Satellite M35X-S329 Laptop was having terrible blue screen problems so I decided to replace the hard drive to try and correct the problem. I installed the new hard drive but continue to get an error message I received before: For Realtek RTL 8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE E-E61: Media Test Failure, check cable PXE-M0F: Exiting PXE ROM The other problem is that my Recovery Disk that came with the laptop is giving me a ''Wrong Machine'' Error even though it is the correct disk. Is there anyway to correct the Realtek error before running the restore disk? Thank you!
  • RyPat Jan 16, 2009
    Thank. I just tried what you suggested. Went through the steps and it still gives me the Wrong Machine error.
    Thanks again. I just discovered a tid bit of information that would have helped. I just contacted a local repair shop that had worked on the computer a few years ago and they informed me that they had replaced the system board and that is why the original disk would not work.
  • 98 Answers
It seems that your computer is not booting from DVD-ROM drive nor hard disk, but is trying to establish a network setup of the operating system.
You have to go to BIOS settings and correct these preferences by making your hard disk the first boot device. Of course that would be a solution if you have operating system installed on it. If there is no operating system installed on the hard disk, you will need to install it. In this case, your first boo device would DVD-ROM or CD-ROM, whichever available.
Posted on Jan 16, 2009
  • Nikola Malesevic
    Nikola Malesevic Jan 16, 2009
    "Wrong Machine" error might indicate that Recovery Disk will work only with the original hard disk. Since you put the new one, Recovery Disk does not recognize it.
    Blue screens of death are not indicator of a hardware failure. You should put the old disk back (unless you're absolutely sure it's faulty) and then try to run Recovery Disk setup. In case of blue screens of death, re installation of the system (or even just a repair) is a solution.
  • Nikola Malesevic
    Then you should ask them to get you another Recovery Disk for free, so you don't have to buy an operating system.
I have a toshiba satellite L645D how can I format it to the factory settings like it just came out of the box.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1.Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2.Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3.Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4.Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5.Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6.Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thanks.
Sep 09, 2011 | Toshiba Computers & Internet
Cant restore to factory settings tried 0,f1 and f8 none work
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
Cannot start my start laptop its as soon as I put the password blue screen appears crash dump cannot start
Would be nice to know error code on the blue screen.That is pointing on the problem-and solution.Anyway, you can try system restore.On boot,computer shows start-up options, and among them is "System Restore".Hit that button and try to restore OS in earlier point of time.Or try Safe mode.Run-msconfig-enter-system restore.To be honest, from my bad experience, blue screen on boot is almost always connected to dying hard drive. Good luck,and keep us posted.
Jun 14, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite pro m35x-s329 cuts off instanly . I hear 3 beeps then 1. It has new battery. I read several problem. Sent it to Toshiba and they said it was fixed. BS Same problem. Any clues?
correct boot sequence cannot be carried out possibly because of hard drive/hardwarefailure.take your harddrive out and tap it --look at boot sequence also by pressing F2 whilst booting ,if you can,here you will see the first few bios pages.navigate using the "tab" or arrow keys.save and exit of restore to factory defaults--good luck!
Davey Snake!
Oct 25, 2010 | Toshiba Computers & Internet
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
My toshiba laptop got a blue screen and can't restart
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
Have a look at this website below. support.microsoft.com/kb/306084 -
Jul 14, 2010 | Toshiba Satellite M35X-S161 Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
CAN'T PUT BACK HARD DRIVE (TOSHIBA M35X-S161) LAPTOP COMPUTER
Is this a IDE or SATA drive?
Is the drive (or connector) possibly upside down?
Dec 08, 2008 | Toshiba Satellite M35X-S161 Notebook
NON DETECTION OF HARD DRIVE
I just responded to this. But I would also suggest that you check the memory on the laptop. It may be causing the Stop errors.
Dec 01, 2008 | Toshiba Satellite M35X-S311 Notebook
Toshiba Satellite m35x-s329 notebook, wireless antena
Do you have a wireless card?
If not you need to get one for it to work!!!
Jan 05, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
290 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
