Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opened, won't close
I have a 1/2 hp Craftsman opener model 139.53635SRT1. Motor worked fine to raise door, when remote is pushed to lower door nothing happens. Electric is working, no obstructions. I waited 15 minutes to see if the overload protection has tripped. (waited and tried several times). When press the wall control the light on the opener comes on and the unit clicks once, but nothing. The same thing happens when I try the remotes.
  • justringo326 Jan 17, 2009
    I have the same problem, my craftsman garage door opened and now it wont go. The electric is still working and the lights still work. It makes a slight "buzz" sound and then nothing. Just like the other problem - there are no obstructions or rail issues that I can see. I tried holding the wall unit button downn - but did not work.
  • j_handloser Mar 29, 2009
    i have the same problem but holding the button will not bring the door down buoght a new switch for inside the garage that didn't work either, eyes are green unless you put something in the way then 1 green light goes out the other stays on door is fine manually lighs go on no motor noise just a click not hung up on the stop screw gears are good need help can't afford to replace everything.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Posted on Jan 17, 2009
New garage door opener 3/4 HP srew Sears. Door open ok, but when close the door went down to the ground and reverse to open. How can I adjust it.
Thanks,
Jay
Posted on Jan 21, 2009
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
We bought a Craftsman 1/4 hp garage door opener. It came with a car remote and a push button. The push botton works fine to open and close the door. But the car remote will only open the door. What do...
If you didn't install the door sensors you must. If you did, make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP garage door opener that has been working flawlessly until yesterday. The door is closed but when I push the wall button, it raises ~ 2 inches and immediately goes back down. The...
First check the door springs. Most likely you have a broken spring. If not, remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is likely stripped.
May 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Sears model 41A4315-7A garage door opener will not raise the door. Yesterda I used the remote and It raised the door half way then stopped. A second push on the remote then lowered it. Then the remote...
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is bad. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Jan 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
895 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
