Cigarette lighter adapter tip has melted
The top of the adapter on my power inverter has melted and will not work
    Scholar:
  • 67 Answers
If it is the tip end that you put into the cigar lighter you can get a replacement at most good auto-shops. You then need to get a soldering iron, and solder wire aswell. When you have all of these, you can begin.
Firstly cut open the old plug.
Then you will see 2 wires attached to thhe metal contacts inside.
Remove 1 wire and note which contact it was soldered to then solder it onto the same contact of the new plug.
Do the same for the second and you are done.
You could put a fuse in line to prevent damage to the equipment it is powering.
Posted on Jan 23, 2009
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I believe...
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
Mar 04, 2015 | Duracell Electronics - Others
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the...
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
May 06, 2014 | NexxTech 175W Power Inverter
Want to replace the lost screw-on male tip of GPS dual socket cigarette lighter adapter
Contact the manufacturer of GPS. They should have the part or replacement.
Apr 13, 2012 | GPS
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
I have a 1989 Jeep Cherokee. After powering a small inverter from the cigarett lighter outlet to power a laptop I now have no power to the turn signal relays, wipers, radio, hot/cool blower motor, and...
sounds like you may have melted the ignition switch and it is just partly working. (i have done this myself before) it is located on the lower part of the steering column you maybe able to use a mirror and a flash light to see if it is melted. ( mine was, but the jeep still started) the switch will have a few wires running to it also a metal rod that comes down the column from the key switch. (please rate this if it help Thank you)
Dec 22, 2010 | 1989 Jeep Cherokee
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
Just want to know if there is a power adapter for this where I can get power from car cigarette lighter
There are adapters to a car lighter for all kinds of AC plugs but not usually very strong. Laser printers can take alot of power. How many WATTS does the powers cord say? Here is one that does a 160 continuous and 300 peak. Check the amps too before you buy, but there are a multitude of these they are called DC to AC converters.
Apr 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Replace fuse
As stated by goalie39, the fuse is located in the tip of the cigarette lighter power supply cord.
Twist off the tip.
The fuse is rated at 2A/256v
Apr 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Cigarette lighter adapter stopped working
I am not specifically familiar with the wiring on your vehicle, but i would say there is still a blown fuse, or the wiring going to your power-port/lighter has shorted.
Dec 06, 2008 | 2006 Chevrolet Colorado
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
