Question about Compaq Presario 1200XL104 Notebook
LCD screen blank out
My Presario V2000 laptop, it black out all of a sudden. No screen display at all. Kindly advice.
  • dvdnguyen200 Mar 20, 2009
    I have the same problem. I replaced the inverter, but no help
    .press the Fn and F4, but no help
    Master:
  • 413 Answers
Look at your function keys (F4 F7) from what i can see on the picture but it will somehow resemble an lcd screen. Try to push the Fn button along with the F-button that has the "lcd" picture at the same time. If this does not work pushing it once try to push it twice. After each time release both buttons and wait a couple seconds after each attempt and see if this fixes the problem
Posted on Jan 16, 2009
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
My scrfeen is went black. I think I need a bulb. I
Hi
Thank you for your query
If your Laptop is working on a external monitor and the Laptops screen has gone blank, this will indicate a fault with the LCD or the inverter (the little chip responsible for providing more power to the LCD)
Please book the Laptop in for further diagnosis
I hope this has been helpful
Feb 27, 2010 | HP Compaq Presario V2000 Notebook
I have a Compaq Presario V2000 and am on it right now but the screen is black and I am using it by pluging it in to a diffrent screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
LCD Screen is black
It could be either, if you can get another LCD screen (same make/model) you can swap to ckeck it out.
You could check the inverter by touching its output and if you get a bit of an electrical shock then you know the inverter is working or check it with a multimeter if you don't like electric shocks.
Dec 27, 2008 | HP Compaq Presario V2000 Notebook
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Screen display problem
sounds like a loose ribbon cable from the MB to the screen.
Here is a manual that should help you take it apart.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Dec 01, 2007 | HP Compaq Presario V2000 Notebook
Presario v2000 notebook problem
Put another monitor and go to the display settings settings advanced and there u can configure display settings if it wont work so just change the monitor
Oct 20, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 1200XL104 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
