Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite bottom freezer refrigerator...water won't work
All of a sudden, my 4 year old above named refrigerator quit despensing water.
  • jackie470 May 11, 2010
    I now have a bit of water trickling out of the dispenser and am still getting no ice after following your advice. So what next? And how do I get the water to flow faster from the water dispenser?
I turned up the temperature in the freezer and the refrigerator. The next day the water was flowing.
Thanks for your time.
Sherry Piper
Posted on Jan 19, 2009
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I just got a new kenmore elite 28cube bottom freezer french door type. I have a reverse osmosis system feeding the ice maker and water despenser on door my water can fill a large glass in like 6 seconds...
NONE / unless the use of water is greater than the supply and what will hapen is the pressure will be to low to close the wate valve and a flood is possible . i used this system on my amana for years without any problems . it may not ever happen but it could . most mfg do not like this hook up . / hope this helped mm
Oct 22, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite water dispenser works but the icemaker doesn't
It is either your water valve in the back of the fridge, the module on the icemaker.
Sep 13, 2009 | Refrigerators
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio
dh means there is a defrost problem with unit you need to repl the controler in evaporator. you will have food loss if not taken care of asap if is under a year old call the tech out there
Oct 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Despenser
Water inlet valve at back of unit may be partially clogged, no repairs on this part, unless it comes apart and has a stainless steel wire mesh strainer that can be cleaned ( not likely), only replacement. BpB
Aug 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
235 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
