Question about Sony Playstation 3 (PS3) Console
My son's ps3 has increasing LOUD noise..sometimes so loud he can bearly hear the games above the noise
  • milan_1994 Apr 04, 2009
    i tried that but still nothing changes.
    it goes back to normal after half an hour
    so annoying
  • 124 Answers
This sounds like the fan is spinning as fast as possible try to put the system in open so it can get air into all the fans if it is in a inclosed space it could over heat the system and fry it just try to leave it in open and maybe put a fan by it to increase cool air to system
Posted on Jan 16, 2009
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 12, 2014 | LG WM-1832C Front Load Washer
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
Loud noise when driving on the interstate, so loud...
Where is the noise coming from? If it is coming from your wheels then it would be your wheel bearings. They can get so loud that you cant hear a thing inside your car due to vibration.
May 20, 2010 | Cars & Trucks
Loud noise in front end at 35-55mph. Sometimes gets softer at around 65mph. Loud humming noise that increases in pitch as the speed increases. Noises persists when engine off and the manual transmission...
Electric cooling fan bearing failed and the cooling fan needs to be replaced. Start with inspecting the cooling fan behind the radiator and determine if that is where the noise is coming from. Replace any worn or damaged parts.
Thank you for using fixya and be safe.
Apr 30, 2010 | 2001 Chevrolet Cavalier
Car has loud knocking sound. gets louder with rev of engine.
Here's what you don't want to hear...A loud knocking noise from inside your engine is generally caused by a crank or rod bearing...when caught very early, sometimes they can be replaced. however, once the noise is loud, the attending crankshaft journal gets "hammered" out of shape and the job becomes very expensive and in most cases more costly than engine replacement. There is one other item that can cause a loud knock...your flywheel. Bearing problems generally cause low oil pressure. If you have that, it's gone...if not, have the flywheel checked before sending the engine to the scrapyard.
Jun 14, 2009 | 1987 Toyota MR2
PS3
It is your outake fans. most likely bearings or something is lodged close to one and doing the old popsicle stick in the spokes trick to you.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Rear acceleration noise
Try rear wheel bearings. The cause a roaring noise that increases with acceleration. Sounds very similar to loud road noise.
Jul 09, 2008 | 2000 Subaru Impreza
Strange ogject in PS3 game console
removing the strange object would be the first thing.
secondly, would be to put it up out of your sons reach.
Finally would be to find out your warranty, you,ll be needing it.
Mike @ compurepair.
Feb 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
191 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
