Question about ASUS P4S8X-X Motherboard
Cannot connect to server
I have 2 front end machines at my grocery store running retail pro software, i cannot connect one of the machines to the server
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    What os are you running?
    Scholar:
  • 87 Answers
Make sure your software is pointed to the correct database server. (the server ip address). Make sure you have a ip address for the client machine. Also make sure the cable isn't the problem by testing it on the working machines cat5 cable. Check if you can actually reach the server by doing a ping to the servers ip. (you will do this at the command line)
Posted on Jan 23, 2009
What are the frontend and backend of any Android application?
Let me make it clear what is front end and what is backend:
Front-end :
  1. Its all about what a user able to see.
  2. It's may be buttons, images, layout, input field etc.
  3. To design these components in android you need XML and Android programming. Therefore these programming are called front-end programming.
Back-end :
  1. Backend of anything is not visible to general user or administrator. It can be a peice of code or a program running on the server machine to serve the user need.
  2. Generally PHP works well as backend languages in website or android application.
  3. Suppose, a user requested to log in with his credentials from the personal computer (front end) and the data went to server to check the credentials. Now, the backend will check the the credentials and decide whether a user to be allowed or not.
  4. Database is also a part of backend.
Now, Coming to your questions:
In your android application :
Front-end:
  1. XML
  2. Android(Java code)
Back-end:
  1. PHP with JSON(on the server if your android application needs a server to connect)
  2. Database.
Hope it helps!
Thanks for reading.
Techment Technology End to EndSoftware and app solutions
Dec 28, 2017 | The Computers & Internet
I have an ATF8000FS1 front loading washer. after wash cycle(when water drain out) It smell like sewer! I leave the door open after use and when not in use. How to solve this problem ........ Please let me...
I recommend purchasing "Affresh" for front loading washers. It is used to clean and freshen up your washer. It can usually be found at any major brand grocery store
Sep 12, 2011 | Frigidaire Washing Machines
How to connect my quickbooks point of sale 9.0 server to a client machine?
The client and the server must be on the same network. If they are properly networked under windows, then the program will be able to see the database managers on the server and connect to the file.
In some cases, your firewall my be preventing the connection.
this site may help:
http://support.quickbooks.intuit.com/support/Articles/HOW12643
Jun 22, 2011 | Intuit - QUICKBOOKS POINT OF SALE -...
Hello. I have a MK500 micro kiosk. I need to know how to turn on the barcode reader. Thanks in advance. Omar
Hi, i work so hard to fix this software.....now i can run this software as a Self PriceChecker at Retail Store..... contact at SonyLal85@gmail.com for full solution in C#, SQL Server 2008 or Novell Server
Mar 01, 2011 | Zebra Symbol MK500 Data Terminal
How do i connect a client directly to my server?I keep getting an error message sayin i'm using an in store sychronization which is not supportedt by this version. My other client is working perfect. One...
First make sure all stations are on the same version, then uninstall the enterprise server/client services from the appropriate machines. Next, direct connect the client to the server. pcAmerica no longer supports the "enterprise" sync (which is lame) but have switched over to sql replication in the newer versions (which costs $$$). so the only way to do sync w/o redundancy is with direct connect. id also check out faq.pcamerica.com for some help
Nov 02, 2010 | Pc America Restaurant Pro Express
MY newerfront load lg machine smells like mildew leaving clothes
Front load washers are very efficient but can create odors not common in top load machines. I would suggest running a cleaner such as Affresh or Smelly washer through the machine, there are instructions on the containers but basically you run a load without clothes on the hottest settings. This will help eliminate the mildew that gets caught between the tub and basket. A treatment once a month will do wonders!
You can purchase these at Target, Lowes or grocery stores near the laundry soaps.
Apr 19, 2010 | LG WM2487H Front Load Washer
Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
Jan 29, 2010 | Pc America Restaurant Pro Express
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
ASUS P4S8X-X Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
