Question about Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator
Frigidaire Water Leak
The water dispenser on our Frigidaire side-by-side refrigerator (Model PHSC39EESS3)suddenly is leaking all over the place. When we press the dispenser, water comes out in not only the usual stream, but from all over the top compartment. We have no idea how to get behind it or pull it out to see if something is disconnected - is there something we can do, short of a service call?
  • ksur Nov 27, 2007
    Our side by side is leaking from the bottom. Water is coming out of the dispenser. We have replace the filter and filter housing, but it appears to be leaking at the bottom of the refrigerator.
  • cjc1961 Mar 29, 2008
    Water dispenser is spraying water out from behind the water tube and on either side instead of dispensing out the appropriate tube.
We had the same problem with water spontaneously pouring out from behind the ice maker dispenser like Niagra falls. Turns out that the water inlet valve was stuck in the open position. This must be a fairly common problem with this model because it took almost two weeks to get the part since it was sold out.
(Part # 241734301)
We were concerned about this happening again, but it appears Frigidaire has upgraded the part (it is not exactly the same as the old one), but you may want to consider getting a "flood safe" water line from Home Depot just to be sure. We were lucky that we were home when the water started gushing. Otherwise, it would have flooded the whole house.
Posted on Aug 13, 2008
Have you found a solution to your problem? We started having a a similar problem with our Frigidaire. Thank you.
Posted on Sep 19, 2007
SOURCE:
Why does my frigidaire washer leak
Hello friend, I appreciate your post!
I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
Aug 17, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaking water dispenser
Sounds like the water valve isn't seating properly, so a small amount of water gets by causing the leak. Replace the dual water valve.
Mar 24, 2014 | Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Water dispenser leak
I
It appears that you hace a water valve problem.The valve has been contaminated and needs to be replaced
Oct 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator Logo
505 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
