Question about IBM Corded Phone IBM412CID
Hold button doesn't work
Hold button no longer works. Transfers work though and intercom. Quite inconvenient considering some offices are in separate locations (1 up & 1 down). Help?
    Novelist:
  • 201 Answers
If the hold button does not work, it's most likely a well used button that has gotten dirty. If you feel up to it (at your own risk) you can take the phone apart and clean both the circuit board contacts and the rubber keypad for the hold button using rubbing alcohol and a rag, q-tip or Cotton ball. This is not a permanent solution if you keep using that button a lot but it may last for years??
Posted on Jul 06, 2007
SOURCE:
Transfer button and specific office intercom buttons no longer work.
It's tough to program on the old DK systems. If you have a newer CiX system:
>Leave phone on-hook
>Enter #9876 (Display: Programming)
>Press HOLD
>Press key to be programmed (only programmable keys on the right)
>Enter 610 plus the extension number
>Press the key to be programmed again (Display: Data Programmed)
Nov 23, 2015 | Toshiba DKT3020S Corded Phone
I work at a new office that doesn't have the information for accessing the voice messaging system. Help?
FIXYA would have no information on it either . SORRY try search for LUCENT.com thru Google
Dec 23, 2017 | Lucent 1872 Corded Phone
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
We have comdial impact 8324 phones here. One of our employees no longer has a DSS button that transfers calls directly to someone's voicemail. How can we program that back in?
Try this:
Storing a DSS Number -
Only one DSS number may be stored at each programmable button location but you may store a feature code or autodial number on the second level for a button location that already has the DSS programmed.
To Store an Intercom Extension Number as a DSS Number :
  1. Press optionS
  2. Press NEXT four times
  3. Press DSS
  4. Press the programmable button
  5. Dial the extension number
  6. Repeat as many times as desired
  7. Press SPEAKER to end.
NOTE: Do not program interactive buttons. If this occurs, you can retrieve functions by pressing INTERCOM "**1" , the interactive button and dial 91, 92 or 93 (from left to right). Attempting to program these buttons can cause features to be unavailable.
You can get more information from:
http://www.mainresource.com/PhoneTipsComdial.html#programming
Nov 04, 2009 | Computers & Internet
Extension call
You need to page an extension.
To program this on a button:
press feature 00
press the intercom you want to change (EX: ext 10)
press the right intercom and *10
press feature 00
To use, just press the button you just programmed. It will grab intercom and dial *10. Conversly, you can press intercom *10 to do the same.
Aug 05, 2009 | Avaya Corded Phone avaparp18d
Intercom on one of the office phones has stopped working?
Press Feature * 0, then press the button you think is the 2nd intercom button. What does it say on the display?
Chances are that the button got erased. Do you know how to get into system admin programming?
Jun 25, 2009 | NorStar M7208 Corded Phone
Unable to use conference button
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
AT&T 974 corded phone
if your dsl is on the same line it will mess up micros for intercome system. Move dsl to another line
Jun 17, 2008 | AT&T ATT-974 Corded Phone
Hold button drops calls GE 29488GE2
does this just happen with the one phone ?
if so, try swopping that phone with another of the same type and see if the problem transfers with the phone or remains at the original location, if it transfers, you have a faulty phone, if it remains, you have a fault in the switch associated with that port.
Jan 29, 2008 | GE 29488GE2 Corded Phone
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
IBM Corded Phone IBM412CID Logo
101 people viewed this question
Top IBM Lands Phones Experts
Ekse
Marvin
Marvin
Are you an IBM Lands Phone Expert? Answer questions, earn points and help others
