Question about Zanussi FJD1666W Front Load Washer
Lg dlg2522w gas dryer with fault code 'tel' or 'te1'. Whatis it?
Dryer beeps and says check filter. Filter has been checked, exhaust tube checked and cleaned, breaker reset. still no go. What now? Thanks! Ken
  • 3 Answers
You cant do nothing sorry it will get damaged
Posted on Feb 16, 2009
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
DRYER HAS NO HEAT. TUMBLER TURNS OK. LINT FILTER CLEAN.
Make sure the dryer exhaust tube is clear of lint and not kinked. Next thing I would check are the thermal fuse and thermostat. Check this out: http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
May 05, 2015 | Washing Machines
DRYER WILL NOT START
If you need to change a filter, do so. Some devices will prevent a start for safety reasons. If lint collects in the exit tube, a fire could occur.
Apr 02, 2014 | LG Steam Washer And Dryer Wm2650hra...
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
Dryer wont heat
Sounds like your heating element has went out. So you will either have to replace it $100 to $150 or purchase a new one
Nov 30, 2013 | LG Tromm Electric Dryer
Dryer won't heat
Your machine may have a bad sensor. go to your computer and type in the make of the machine add troubleshooting. you should have a selection of sites to visit. Usually the fix is simple and You Tube has many video's available that you can view that give you step by step instructions on fixing the problem.
Nov 30, 2013 | LG Tromm Front Load Washer And Dryer Set
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
I have a Maytag front load dryer. When you push start everything runs good except the gas won't kick on. I have vacuumed out inside between the walls and drum, removed the lint filter and shoved a...
first make sure gas is on then turn it on and look at the ignighter should be as brite as the sun if so you will here a click when tha gas is to come on and you get nothing then the coils are bad easy fix make sure you unplug it then unplug coils 2 screws that hold it down you can not put them in wrong
Jun 26, 2009 | Maytag Neptune MLE19PN Front Load Stacked...
Zanussi FJD1666W Front Load Washer Logo
326 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
