Question about Seiko Smart Label Printer 100 Thermal
I have a Smart Label 100 printer that won't print.
The printer says 'cancel printing'
WHEN THIS HAPPENED TO ME, I DELETED THE PRINTED AND REINSTALLED IT...
Posted on Aug 20, 2009
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Seiko smart label printer 100 not printing
A censor within the printer probably needs cleaning.
Apr 08, 2014 | Seiko Smart Label Printer 100 Thermal
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
My smart label printer 100 is backing up at times when I try to print a label and doesn't print right, it skips letters or numbers and continues with the rest of the info. Like abcde will be abe
This skipping could be caused by a roller not turning causing the paper to be forced to much into the thermal.
Repair is quite difficult the unit would need to be taken apart and the feeder investigated. You could put some machine lube on the roller part, but its quite involved.
Another reason could be the module inside not working correctly causing it to print like it is.
If you update me with additional info I could be more of a help to you.
Regards,
Rulds2008
Jul 21, 2011 | Seiko Smart Label Printer 100 Thermal
After each label I print the printer automatically advances 3/4 of the way through the next label. Is there a setting to stop at the end of each label?
I don't know the particulat incantations for this printer, but it sounds like the "form length" or "label length" is not set correctly. Normally the printer will advance to the beginning of the next label once the printing is complete. Check the menu or setup program for the label length.
Let me know if you can not find this and I'll research the exact commands.
Thanks,
Dan
Aug 12, 2010 | Seiko Smart Label Printer 100 Thermal
Zebra 105SL prints 90 degs to what's on the screen
Print out a Cancel Self Test label:
1. Turn the printer off
2. Press and hold the CANCEL button while you turn the printer on.
If the label that prints out looks normal, you have a config issue in either your printer driver or your label software's page setup.
Mar 04, 2010 | Zebra 105SL Thermal Label Printer
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Nov 22, 2007 | Zebra Z4Mplus Label Printer
Seiko Smart Label Printer 100 Thermal Logo
830 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
