Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitaci volume problem, pls help !!
I have the same issue as DDOD "Just recently I have a volume issue. The volume used to be loud at setting of 24 now I have to turn it up to 35-40 o hear it. I have the same issue with my 53" RP TV, I also noted that when I check mark the "loud" button on the audio setup menu, I do not hear a difference, I have to turn the volume up above 43 to hear the TV properly, I have a dvd player inputs to the TV, get same result, so its not my cable box or external device, please help
  • 1Bonzai Jan 08, 2008
    I have the identical problem with my 51S500 which just started (1/5/08). Normal listening setting was at 12-14, I now have to boost it to 25-30 to get the same volume level. I have checked all settings, and nothing has changed. I have yet to get behind it to check the cables. The other thing is, I have 2 bookshelf speakers hooked up to the external speaker jacks, they are affected as well. Playing a movie through the DVD player does eliminate the problem though. The sound is normal when playing a movie. Given the age of the original post, I don't have high hopes of a solution.
My problem is solved. There is a separate volume control on my HD cable box that had been turned down. By turning it back up the issue was corrected.
Posted on Jan 08, 2008
How To Fix Volume Issues on Headphones?
open sound settings in windows system settings ?
Jun 13, 2014 | Gateway Computers & Internet
How to volume the KX-T7730.. if they have incoming call... i see only the light of the button but no ring.. pls.. help me
The volume control only changes the volume of the handset, headset or speaker. The volume for the ringer is on the left side of the phone, there are three settings, mute medium and loud.
Jun 11, 2014 | Panasonic KX-T7730 Corded Phone
Cannot adjust the volume - always too loud
One of a couple of possible issues here:
With set on volume goes way up on its own and will not with remote or buttons on set go down.
Put the remote away or remove batteries to see if it is doing this (unlikely but easy to check)
what issue do you have and are you using a cable or some kind of box with the set as they have Volume controls on them also.
Apr 05, 2012 | Televison & Video
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
My HTC wildfire will not ring out loud
pls set ur volume full in using of volume control buttons and set in ur mobile
Dec 26, 2010 | HTC Wildfire Cell Phone
SPEAKERS
Hi Jonathan,
Pls check if the cables are connected to the right port.
Also check the monitor volume settings.
Pls check with a set of powered speakers.
Pls run dxdiag from Run in Start menu if you are using windows.
Also you can check for any issued with the drivers or any driver updates.
Pls try a system restore also if none of the above steps work.
Jan 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Jul 28, 2007 | Dell 5650 Computer Speakers
Volume
I have the same problem with my 51S500 which just started. I used to have it set at 12-14, now needs to be 25-30. Playing DVDs is not affected. External speakers hooked into the external speaker jacks are affected.
Apr 02, 2007 | Hitachi 53UWX10B 53" Rear Projection...
The volume is way to high even on the lowest setting
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
May 29, 2006 | GPX DV7500 System
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
207 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
