Question about Asrock K7S8XE Motherboard
3 beeps on startup with asrock k7s8x motherboard
Can't find any beep codes on google so im a bit stuck. just 'upgraded' a pc to this "new" motherboard. everything worked perfectly inthe other case but now i cant load windows. to start off it tried loading windows but now it goes onto the 'choose how to start windows' screen, i cant start windows, i cant roll back, i cant start in safe mode. so i checked the cables to make sure they were all plugged in correctly, now it starts up and beeps 3 times and does nothing at all. no display or anything. the only thing happening is the fans and the hard drives. its got an amd 2500 xp cpu running at 1800mhz im not impressed:(
  • 3 more comments
  • Blue
    Blue Jan 16, 2009
    No just 3 beeps of the same length and not particularly long ones either
  • Blue
    Blue Jan 16, 2009
    i have now tried 3 different memory modules and its still beeping at me! i dont understand why its gone from trying to load windows to doing nothing. any other suggestions?
  • Blue
    Blue Jan 16, 2009
    sorry no luck, maybe the motherboard or the memory slots are just knackered! i have tried all 3 slots and just put in some known working ram but still nothing. thanks for your suggestions though
  • Blue
    Blue Jan 16, 2009
    just as an update: i seem to have discovered the problem by process of elimination, it seems that i may have been right and there is a fault either on the motherboard or with the slots themselves. i have now put everything into a different case with a differentn motherboard and all works perfectly if a little slow!
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Is ti two short and one long beep?
Same here! ASrock sucks!!!! How sad!
Posted on Jan 12, 2010
  • 98 Answers
This beeps indicate faulty RAM memory.
Warning: Following procedure requires removing physical parts within the computer.
If you recently added memory module, remove it and try again. If it doesn't help, try removing all of the modules and then putting them back. If nothing works, memory is faulty and you should buy a new one or ask for warranty if you have it.
Posted on Jan 16, 2009
  • 1 more comment
  • Nikola Malesevic
    Nikola Malesevic Jan 16, 2009
    This beeps indicate faulty RAM memory at AMI BIOS versions. This version is installed on your motherboard. Maybe there's dust or the dirt in the slots on the motherboard. Try blowing or use a brush to clean the slots. Or try other memory slot.
    I have no other suggestions than this.
  • Nikola Malesevic
    You're welcome. Sorry it didn't work out.
  • Nikola Malesevic
    Quite possible the motherboard is faulty. Thanks for update.
K7s8x asrock won't enter post after inserting ram upgrade
need more info.What memory did you use?
That MB requires either DDR PC2700 or DDR PC3200 Unbuffered,NON-ECC memory.
Max of 1gib per slot.
Jun 25, 2016 | Asrock K7S8X-R3 Motherboard
Asrock p4v88 9 beeps
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Feb 15, 2014 | Asrock P4V88 (P4V88 RAID) Motherboard
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
I have a m,b, asrock 845 presscot mothwer board cpu fan is running but not booting and not display .
are you getting any beeps. These can tell you what your problem is. Just google asrock beep codes
Aug 25, 2010 | Asrock 845GV (P4I45GV) Motherboard
At startup i get neverending beeps (4 second long).always the same beeps. the monitor remains black. can you help me?motherboard: msi pm8pm-v. sonia
please find the range of error beeps below try to associate the error beeps you receive with the error message and possible solution.
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
1 short, 1 long beep System board error also visit the below site for ore information
http://www.helpwithpcs.com/upgrading/post-beep-codes.htm
Dec 05, 2009 | Intel Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Asrock motherboard
Look HERE for a list of bios beep codes
May 18, 2008 | Asrock P4VM800 Motherboard
Blank screen after xp welcome screen no power to keyboard
Ok, with your current set up, what beeps are you getting? Also, while you have a blank desktop, hit CTRL+ALT+DELETE and you'll have Task Manager come up, click File and then New Task and type in "explorer" without quotes and hit enter. That should restore your desktop. Let me know how it goes.
Sep 07, 2007 | Asrock K7VT2 Motherboard
Asrock K7S8XE Motherboard Logo
2,596 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
