Question about Kodak Easyshare C813 Digital Camera
Transfering pictures from camera to card
How can i transfer the pictures on the cameras memory to my sd card.when the card is not installed it gives me the option to copy, however when the sd card is in the camera i cannot revert to the camera's memory. I cant find my USB lead to transfer directly onto the PC so the only way for me to get the pictures from camera to card is to transfer them somehow!!
  • Anonymous Apr 27, 2009
    I need to transfer the pictures on my camera's memory to my sd card. I have a card reader however the cord for the card reader does not fit into the camera. Is there a way to transfer pictures from the camera's memory to my sd card so that I can then use my card reader and send them to my pc?
    Thanks!
    Problem Solver:
  • 6 Answers
The USB connection is the same USB that the Razr cell phone and a lot of others use.
Posted on Jan 17, 2009
How do I transfer pictures from the internal storage to a sd card?
hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card? Follow these steps:
  1. Insert a memory card into your camera.
  2. Turn on your camera.
  3. On the camera, press the Review button then the Menu button.
  4. On the Setup tab in the menu (your menu tabs might be named differently), select Image Storage.
  5. Select Internal Memory.
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
Nov 05, 2017 | Cameras
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
How can i transfer my pictures when i can't turn it on? new batteries installed.
Hi Wendy,
If you are using an external sd card, you can use an sd card reader. That is my favorite way of transferring pictures to my computer.
They are cheap and you can take tons of pictures in high resolution.
If you are using the on camera memory, you can connect with the usb cable to your computer and transfer that way. If you give me more info, maybe I can help. Here is a link to the manual for your camera.
Nov 29, 2011 | Polaroid I1037 Digital Camera
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
I have a nikon coolpix p80 and i need to transfer pictures form the camera memory to the memory card.. how do i do it?
You can do it through computer, using a memory card reader or there are many new laptops are with a inside memory card reader too, then you can transfer pictures from the camera memory and to the memory card.
Dec 30, 2010 | Nikon COOLPIX P80 Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
Transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Oct 15, 2007 | Samsung Digimax L60 Digital Camera
Transferring pics
I think there is a copy to card option in your camera.
It would enable you to transfer pictures from internal memory to your SD card.
You may check the website of your Camera Manufacturer and download the English manual online.
Oct 10, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
154 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
