Question about Whirlpool Refrigerators
ICE MAKER DOES NOT CYCLE. NO WATER IN TRAY - Whirlpool Refrigerators
I REPLACED THE ENTIRE ICE MAKER. THE PROBLEM WAS THAT THE TIMER WHEEL(GEAR) HAD SHEARED OFF . THE REPLACEMENT OF THAT UNIT COST ALMOST AS MUCH AS A COMPLETE UNIT. BY REPLACING THE ENTIRE UNIT, I PRECLUDED THE POSSIBILITY THAT THE SHEARED OFF SHAFT OF THE GEAR WAS CAUSED BY A JAMMING ELSEWHERE IN THE UNIT.
Posted on Jan 17, 2009
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
ICE MAKER INOP
Check the water control valve on back and bottom of refrigerator. One side is for the dispenser and the other side is for the ice maker. When the ice maker begins a cycle the thermostat inside the ice maker begins to warm the bottom with a heating element to allow the ice to move freely and then dump into the container beside it. As the cycle reaches its final resting place a limit switch is pressed inside the ice maker to refill with water and start the process again. So if the water valve does not open and the tray remains empty and the ice maker will try to cycle again if the thermostat says that it is cold enough again. Check your model number again and I will try to get you some drawings. The number looks good but can't seem to pull it up. Let me know what you see and find. Try filling the tray with tap water and see if it will cycle after freezing. Thanks, Sea Breeze
May 20, 2009 | GE Refrigerators
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Apr 28, 2009 | Kenmore Refrigerators
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
