Bissell 1692 PowerSteamer Upright Vacuum
Problem for Bissell 1692 PowerSteamer Upright Vacuum
Brush not turning and no suctions !
By yhpark0485 on Jan 16, 2009
my powersteamer model 1692-c .
When the switch is on, motor is running but no brush turing and suction.
checked the belt but OK. Gear which turns the belt is not turning !
pls help
park
Comments:
Jan 16, 2009
- Dear reddevil6,
thank you for ur reply.
cogs on the belt are OK.
Pulley turing belt is NOT turning when swich is ON.
i did not see flat belt, red plastic screen.. where are they located ?also i do not understand oblong gasket,clear window so on..
video or picture would help, If they are able,,,
thank you
Jan 28, 2009
- Finally I managed to solve the problems by replacing belt etc...
Now brush is turning and good suctions BUT the cleaing solution
liquid is not discharging continuously when the lever is pressed.
therefore CAN NOT Clean the carpet. it discharges the cleaning
liquid a little bit and stops...
Is there problem in my pump??
pls help...
Same Problem
Apr 08, 2009
-   need instruction on how to install the gear belt.-   spruce2us
Solution #1
posted on Jan 16, 2009
Not Helpful)
reddevil6
Rank: Guru
Rating: 88%, 1797 votes
If the cogs on the belt and brush roll are ok, then probably the cogs on the pulley are worn off, or the pump isn't turning, is the flat belt ok? If all of this is ok, then replace the pump, part # 2107181If no suction, is the black oblong gasket on the top of the clear window. It seals the gap between the tank and the window, no suction if it is gone. Also should be a red plastic screen on the edge of the tank lid, it may be clogged.
Comments:
Jan 28, 2009
- On the left side there is a small door you can rmove, check the flat belt, make sure it is tight, if loose, replace it. Is the top locked down in the back, if it has broken loose, the top will have raised and can't **** the water from the tank. Is the gasket on the bottom of the tank valve, if it isn't and is sitting loose in the hole, then re-install it onto the bottom of the tank. Pump may be bad.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bissell 1692 PowerSteamer
Questions and Unsolved Problems for Bissell 1692 PowerSteamer
Do you recommend Bissell 1692 PowerSteamer Upright Vacuum?
Answer
Answer
Lost a small wheel at the bottom of the suction unit. Where inTel Aviv can I get a replacement
Answer
I do not have any power to the motor on a Royal 4600 canister vacuum, although I do have power to... (More)
Answer
brush won't turn, belts intact
Answer
roller brush does not rotate if there is a belt I can't open that part of the vacuum to look. Vacuum... (More)
Answer
DC 28 -cannot engage the rotor brush post unraveling a cord wrapped around the brush
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
