Question about Sony PlayStation 2 (PS2) Console
Why does my lense have problem.
I have changed my lense 4 times . nearly 2 month after lense is problemed so tell me what i do.
  • artbysmith May 11, 2010
    Also to add what was the reasonig on replacing the lens so many times...whats the problem....read errors. skipping.?? clarify please
    I am curious to see or I should say ask if you are running you PS2 on its side or flat on the floor ( like the PS1 )? because if so then I heard of an issue where the lense is actually hit ( touched just slightly ) by the spinning disk and being on the side can cause this I think....I will check into it for you. So if you put it flat that may solve the problem.
    Problem Solver:
  • 5 Answers
Before you replacing a new lens please cleaned your lens first
Posted on Jan 16, 2009
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
Jan 30, 2014 | Tissot Watches
I have a 52 in rca projection screen tv that looks like its stuck in 3d mode, how do I fix it?? Its got red and green lines everywhere. It was in storage outside for 6 months as well
It has dust on the lenses. My RCA rear projection uses a 7/64" allen key. take the speakers' cover off and then remove (I think) the three screws below the button pannel, and 2 on each side on the back on button pannel. the projectors should be easy to see. I turned mine on when I cleaned the lenses so i could tell if there was any streaks.
Once the lenses are cleaned go to auto convergence in the setup menu and your problems should be fixed. Good Luck.
Mar 09, 2010 | RCA Televison & Video
We have a Nortel T7316E telephone and a Telephone User Card but I can't find where it tells how to change the time your telephone is displaying. Can you help me?
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 05, 2009 | NorStar T7316E Corded Phone
Turn the power off and on again
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Broken Lense
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 30, 2009 | Sanyo VPC-E760 Digital Camera
Pentex model, optio E60, get a message'"lens error:0x01110000"
after replaced with 2 fully charged battery, and pressed a few times on/off, it worked. and problem solved.
Feb 14, 2009 | Pentax Cameras
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Zoom lense going in and out when turned on
Try taking the batteries out and plugging it in. If it powers on, put fresh batteries in and try again off the AC. Once it's powered up from the AC, unplug it and see if it stays on. If it does, try restarting it. Good luck.
Aug 18, 2007 | Olympus FE-110 Digital Camera
Dust problem
Ive only had my DS for a few weeks, but have changed lenses many times. I havent noticed any dust yet at all in any of the 300 or so images that Ive really taken a good look at. I am pretty careful though -always cover the lenses with the rear cap and fit the lense immediately, always do it in a place "protected" from wind/dust etc (as much as possible). Just like I always did with my non-D SLR. LOL the only time I took any camera to a shop for "cleaning" was when I stupidly blew into the focussing screen to get rid of some dust -I didnt use a blower, but used my mouth...and spat into it by accident :( $20 later it was fine.
Sep 08, 2005 | Pentax *ist D Digital Camera
Sony PlayStation 2 (PS2) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
