Question about Microsoft Xbox 360 Console
I plug my xbox 360 in everything is all plugged in... but i when i plug the power in a fan starts up no lights no green or red lights NOTHING. and it wont turn on wat can i do
  • 54 Answers
Talk with microsoft and give him a description of your problem. It sounds like the main board is bad but dont quote me on that. You have a one year warrenty on damages like that to your xbox so give them a call and let then know of your situations.
Posted on Jan 16, 2009
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Microsoft Xbox 360 Console
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Plugged in powerless 360
The power adapter would have gone green when it was working normlly, its what it does, you need to replace the power adapter 'brick' as it is either faulty or was over heated due to travel. Good luck.
Nov 06, 2009 | Microsoft Xbox 360 Console
3 red lights, but nothing turns on
sorry to say that is the Red ring of death your gonna have to send it to microsoft and they will repair it for free
Jun 14, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 3 red rings.I cant play my xbox 360 because of that red light?Can you help me?
Here is a linl to MS website. It doesn't look very good. Make sure the light on your power supply is green. Also, unplug the unit from the wall, wait a minute or 2 and plug back in and see if that helps.
http://support.microsoft.com/kb/907534
Mar 02, 2009 | Microsoft Xbox 360 Console
Whats Wrong With My Xbox 360?
it has to be on the wrong plug in ins or on HDTV. if you need more help my email is: dracohackess@yahoo.com i got one on christmas to i sorta like SOFTLY boped it and it booted up. sorry bout it
Dec 27, 2008 | Microsoft Xbox 360 Elite Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
4 red lights flashing
The TV screen or monitor remains black when you start an Xbox 360 console.
This behavior may occur with or without a game disc in the disc tray. The console appears to be on because the green power light illuminates and the fan continues to operate. However, the screen remains black.
Click on the IMAGE i paste here below:
Thank you,
~micro
May 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
