Question about Maytag Neptune MDE5500AY Electric Dryer
Hear a periodic banging during rotation of the drume
While drying, I notice a banging sound that seam to come from within the chassis, near the left side of the drum. How can I crack the top,, and see what's inside.
  • Thomas Gray Feb 01, 2009
    There is a banging sound on the left side of the machine that seems to have just started recently. It happens once per rotation of the drum. When I rotate the drum by hand you can see the left side of the dryer bulge out where the drum is contacting.
I had a screw that was protruding from the back side of the dryer baffel and it hit the left side of the dryer during each rotation.
1. I opened the front dryer door.
2. Removed the dryer door by removing the four screws holding the hinge on and the four screws that hold the two white cover plates on the opposite side.
3. Pulled the front housing piece off of its snaps and lifted it up off the hinges that hold the bottom of the housing piece.
4. Then I was able to rotate the drum into a position where I could access the baffel screws and tighten the loose one.
See also:
http://www.fixya.com/WikiManualView.aspx?thid=153218
Posted on Feb 01, 2009
Usually you can check it at the back cover, check if the dryer tub is directly mounted or connected to the motor, then check the rubber stabilizer or spring stabilizer of the motor which is connected to the base. This stabilizers are responsible of the balance of the dryer tub during high speed operation or rotation of the motor. check this stabilizers and replace it if it is defective or weak.
and one thing more, just make sure that when load your wet clothes see to it that you load it at the center of the dryer tub, so that when the motor starts to spin at speed it is in a balance position.
Posted on Jan 24, 2009
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
When the dryer is on it makes a loud clunking sound during each rotation
Check to see if something was left in a pocket when dried and fell out. like a coin, a magnet, a wrench. Often, things fall out of pockets and make a loud clunking sound when the drier is turned on.
Feb 05, 2011 | Dryers
MY DRYER HAS STARTED TO HAVE A KNOCKING SOUND ON ALL SETTINGS PERIODICALLY DURING THE DRYING CYCLE. IT SOUNDS JUST LIKE SOMEONE KNOCKING ON FRONT DOOR OR LIKE A SHOE BANGING AROUND IN DRYER. MAYBE NOT...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Fisher and Paykel DEGX2 Dryer
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
heatman101
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Makes a banging noise when it rotates
Check the druer at the seam of the drum, inside the dryer at the seam of the drum there is probably a crack in the drum, also if it goes away after the dryer has a chance to heat up it may just be the seam hitting the wheels, check for the crack first, very common.
Jan 07, 2010 | Dryers
Maytag pyet244ayw---the dryer would not turn off.it had to be manually shut off. now, it turned off during a drying cycle. i can hear a whining sound when i tried to restart it.
Could be the belt.
Disconnect power.
Using a putty knife, slide it under the top and front panel of the dryer. There is one clip near each front corner. Pull up on the top panel while depressing the clips.
With the top up, you can see the drum and the belt should be around it and tight. You should be able to rotate the drum with your hand with some resistance. If the belt is not present then it is probably broken and under the drum. If this is the case, the whining you hear is the motor turning under no load.
Please post if this is the problem or if other to assist others with a siimular problem.
Dec 15, 2009 | Maytag PYE2300AY Electric Dryer
Tumble dryer dose not rotate
Sounds terminal.
If any bearing becomes too siff to rotate then the may be consequences for the drive, (i.e. perhaps the motor has burnt out).
If there are signs of extreme wear, then perhaps it is time to replace it.
Dec 14, 2009 | Dryers
A piece of the steel srum tore out during drying
If you can find a friend who is also an amateur welder or a professional,,you can have that piece welding back in for cheap,,,P.S. you will have to repaint the inside of your drum though afterwards
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bumping noise
Just had the same provlem and the drum is in the back of my truck. Open the door and manually turn the drum slowly until you hear the thump. Look at the seam that runs along the baffle and pay attention the seam near the raer and see if it separates when you hear the noise. A common problem is the weld breaks and you will need to replace the drum or take it out to have re-welded unless it is still under the year warrant which I am guessing it is not. Don't even try to call LG because they will not help in any fahion.
Dec 29, 2008 | LG DLE2512W Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
134 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
