Question about HP DeskJet 3320 InkJet Printer
HP printer Model 3320
This printer has been barely used in the three years it sat in my motor home. Now have a new (with Vista) laptop and the printer does not respond to printing commands. The laptop recognizes the printer but the the printer does not respond. HP tells me the printer is the problem (too old) but can be fixed on line (for the cost of a new one). That tells me it's a software issue with the printer. Does that make sense? Anyone know how to address the problem? Any input appreciated. Roger
  • Lord Raghav Mar 08, 2008
    I do have the same problem. it seems there is no solution?
If it is software problem try installing default drivers for HP deskjet 3500 from within vista itself. Solved my problem. May the force be with you.
Posted on Aug 06, 2008
    Sergeant:
  • 458 Answers
The print Head has gone bad. Not using a printer that often will dry out the print head. The print head is where the ink goes. Try to get a cue tip and put some Alcohol in the place where the ink goes through. These should be small sponge like things underneath the ink cartridges.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
SOURCE:
We installed the hp 3320 software on our new laptop. when we print items it sends it to the printer; however its printing blank. the cartridge is full. how can we fix this problem?
The problem is a "clogged" ink-path -- the ink is not getting sucked ("stucked" without the 'T') into the ink-jet mechanism, and is not getting sprayed onto the paper.
Use the HP Printing Assistant software to run a "head-cleaning" cycle, to see if the clogging can be done.
P.S. FIXYA _censors_ some words, e.g., 'calm' is OK, but switching the middle letters to be: ****
will be censored. :-)
Dec 08, 2010 | HP DeskJet 3320 InkJet Printer
Compatibility of HP Deskjet 3320 printer with Vista?
1st you remember your previous OS is Vista or others. Then You will installed this Printer in your compatible Opearating System.
Thanks
Aug 12, 2009 | Computers & Internet
Lost Scanner Driver for HP Laserjet 3320
The drivers for the 3300-series are right on HP's website. The link below is for Windows, OS X, and Linux. If problems continue, look further down the driver page for the OCR libraries.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=66364&taskId=135&prodTypeId=18972&prodSeriesId=66359&lang=en&cc=us&submit=Go%20%C2%BB
If the link above is broken, go to http://www.hp.com/#Support and type in your hardware's model number or series number (e.g. Laserjet 3320, Laserjet 3300 series)
Apr 13, 2009 | HP LaserJet 3320 All-In-One Printer
I REFILLED THE BLACK (C8727) , AND THE COLOR (C8728) ,
Go to:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75035&lc=en&cc=us&dlc=en&lang=en&cc=us
Select Vista (or Vista 64-bit if you are using the 64-bit version) and download the appropriate drivers from there. These drivers should give you access to all of the necessary maintenance options including resetting ink levels (tell the driver you are installing new cartridges, remove and reinstall the existing cartridges to make it do the reset).
Test page coming out green indicates a problem with the ink cartridges since it should be using the black cart for most of the page.
Mar 26, 2009 | HP DeskJet 3320 InkJet Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Lost cd to install printer. Need to install hp deskjet 3320 printer to my program update.
For Windows XP, download here:
ftp://ftp.hp.com/pub/softlib/software2/COL1572/dj-7057-4/3320-enu-win2k_xp.exe
For Windows Vista, read this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&dlc=en&cc=us&lang=en&product=75035
Hope this helps - remember to rate! :)
Oct 02, 2008 | HP Office Equipment & Supplies
I have a new computer and i can't get my #3320 hp deskjet on line i do not have the download disc can you help thanks bob harper1634@yahoo.com
You can download the driver here, directly from HP.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75035&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Choose your operating system from the list, and download.
Please note that if you are using Windows Vista, HP has very limited Vista support for that model.
Also, be sure to UNPLUG the printer from the PC before installing the software, and ONLY plug it in once the on-screen instructions tell you to do so.
Apr 15, 2008 | Office Equipment & Supplies
My HP Printer Deskjet 3320 is not working with Windows Vista
You can follow Hp's Installing and Configuring an Alternate Driver in Windows Vista. Click this link provided by HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&cc=us&lang=en&dlc=en&product=75035
Before you follow though with Hp's alternet driver site. Please run windows update for Vista un till no updates are left. If your printer still fails to run correctly than try HP's alternate drive.
Good luck & kind regaurds..
Mar 08, 2008 | HP DeskJet 3320 InkJet Printer
Download printer drivers
hello
HP Deskjet 3320 drivers can be got from here .
riz.
Dec 08, 2007 | HP DeskJet 3320 InkJet Printer
Printer problem
Use Vista's 3500 already present driver.
see this LINK
Nov 30, 2007 | Office Equipment & Supplies
HP DeskJet 3320 InkJet Printer Logo
91 people viewed this question
Clive
Clive
Thomas F. Schneider
